Knock-Off Hammer
Editor_Reid
Platinum
Finally broken in!
twas_brillig
Ummmm...... Nice handle?? Doug
nevets
Are you sure you aren't over tightening your knockoffs just a little bit? Or maybe that hammer gets used for purposes other than just whacking knock-offs....like assembling IKEA furniture or cracking open macadamia nuts?
Editor_Reid
Editor_Reid
Platinum
Well, that wasn't from one tightening. That's the result of many years of use.
Now that I've driven the car something like 75-100 miles since those new tires were installed, I'll give the knock-offs a little more encouragement to stay put. Then they should be good for the duration.
By the way, in my lifetime of driving cars with spline-drive wheels, I've had two come off while driving. Fortunately neither incident was at enough speed to result in serious damage (one destroyed a fender, but that's all), but I have never had a problem with wheels being tightened too much.
John Turney
A sailor on our boat (in Pearl Harbor) had the Base Auto Shop do his brakes on his Triumph. After they were done, he drove back to the pier and one front wheel came off and rolled into the water. The shop had reversed the hubs.
Towing the car backwards would have the same effect; DON'T tow a car with spline/pin-drive wheels backwards.
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
G Lead Head Knock-off Hammer Austin Healey 10
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
T Knock-Off Spinners Austin Healey 43
TomMull Knock Off Tool Restoration & Tools 6
CJD TR2/3/3A Knock Off Differences Triumph 13
Feathers Knock off wheels for sp250 Other British Cars 6
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
Healey Nut Knock off removal Austin Healey 3
J knock, off tools Jaguar 6
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
T Looking for used set of Knock off minilites Spridgets 4
kodanja Knock it off? Triumph 13
kodanja Knock off grease? Triumph 14
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
W knock off Austin Healey 7
S Knock-Off Hub bearings - Can they be removed? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
6 Knock off minilites MG 3
Michael Oritt Safety-wiring knock-offs Austin Healey 24
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
steveg Has anyone used a knock sensor? Austin Healey 0
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
V Panasport Fake Knock Offs Triumph 8
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
DNK KNOCK- KNOCK-KNOCK Triumph 59
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
C Wire Knock-offs Triumph 9
