KNOCK- KNOCK-KNOCK
DNK
I wish this was a knock ,knock joke :cryin:
I finally changed the oil in the Wedge,if you remember the post. A couple of days later I noticed a tapping when it warms up.
Now I think it is more like a knocking after it is warm.
Yikes
Tinkerman
Probably best that you stop listening for the knock knock, and start figuring on ways to get the engine out. A bummer indeed!
Let us know the diagnosis.
Good Luck, Tinkerman
DNK
DNK
On this car is it possible to do underneath without pulling the motor?
swift6
There is a good possibility that it is a lifter that's not pumping up all the way. Not that big of deal really. Noisy, but I have been advised that its not terminal. I have a "sticky lifter" in my TR8 as well. If its a lifter you should be able to hear it easily from outside or in but with your head in the engine compartment you should be able to isolate the sound close to the head. Upper part of the engine anyway.
I wasn't told until later but it sometimes happens when the oil pump partially loses its prime. Which can happen when you change the oil filters. To limit this headache, prefill the new filter with oil and have it ready to go on as soon as you take the old filter off. Then when you start it back up after filling the crankcase there is minimal loss of prime. Or so I have been told.
If it is a bearing knocking... don't wait too long to find out for sure.
DNK
DNK
My bad then, Woody told me to do this and remember my problem with too much oil in the pan? To help the situation out I changed the filter again and of course I didn't want any fluid in it so I put it on dry. So how to I get it to pump up. It seems only to do it when the motor is HOT. It make a loud racket when the motor is stumblingly at low idle.
AltaKnight
If it's a deep pitched noise it could also be piston slap, particularly if it tends to reduce/go away as the engine gets warmed up.
I know, I know, I'm not exactly making you feel any better, however piston slap can often be rectified with a simple piston replacement as the bore is often still in good shape.
tr8todd
Lifter noise is the most common knock you will hear. Second would be a from a broken valve spring. Remove the valve covers and take a look. If it is a bearing noise or a piston slap, your looking at a rebuild. What has been done to the engine? Does it have any mods? Sometimes you can narrow down where the noise is coming from by holding a long screw driver against the motor and also up to your ear. Not as effective with an alloy motor thou.
DNK
DNK
no mods and as the post says. When it is cold quiet. It comes about after it is warm.
I asked Woody if the Syntec would cause it if it was thinner and he says same viscosity so probably not.
PATR8
My 8 has a valve that likes to stick if I do not drive it for awhile giving me a light smoke from my right exhaust. The more I drive it the less it gets until like now the smoke is gone.
Post 700
poolboy
DNK, If you can get the oil pan off, tapping on the connecting rod bearing caps with a metal hammer will give you a different sound when/if you tap a rod with a spun bearing.
philman
I found that my 10mm deep 1/4 socket fits on the oil pump drive shaft and I primed the oil pump with an electric drill motor until oil comes out the rocker shaft.
When I put my new exhaust on my engine I could hear noises masked by strait header exhausts. My engine also makes a noise when the oil warms up. I have a mechanical guage on it, at start up when cold it reads about 30lbs and drops as the engine warms up to about 10lbs at idle. That's when I hear my the noise in my engine. Interesting you bring this up at the same time I bring mine back to life and have the same situation?!
AweMan
My experiance with noisy lifters is, they typicaly make nosie when they are cold.
A spun bearing will be dry {no oil getting to it}, therefore it will get loud in very short order and either sieze up or break a rod. At the very least score the crankshaft very badly.
A worn bearing typicaly exhibits the symptoms you describe, Warmer = louder.
One way to tell for sure is remove one spark plug wire at a time while the engine is warm {making noise} and running. IF the noise goes away, that is the cylinder that has the problem and the problem IS a worn rod bearing.
If the noise presists there could be a number or difficulties such as piston skirt slap, broken piston, worn wrist pin, Possibly a lifter noise but normaly lifter noise is more of a tick tick sound. Worn rod noise gets louder on acceleration and deceleration, there is a happy medium inbetween aceleration and deceleration where the noise all but dissapears.
In any case, a fix before running the engine much further is a MUST DO!
DNK
DNK
Actually i don't think it gets louder as I accelerate. It also will go away at times. I f I stop for a little while ,as to go into a grocery store,it will not be there.
DNK
DNK
Well,it is definitely in the bottom end :cryin: :cryin:
Took the Valve cover off and while it is in the garage it really has that memberable sound of a rod knock.
Anybody want to hear?
philman
You can remove the oil pan without pulling the engine. You need to lift the engine about 2" to clear the steering rack (I have a manual rack). I disconnected the headers, removed the engine cover, raised enough with the shop crane to remove the front bolts to the motor mounts, lift enough to get the oil pan out.
I found out that it is better to remove the strainer before removing the windage tray. There is still some oil in the windage tray. You should be able to get to the rear six rod bearings with no trouble.
This link helps explain noisy rod bearings.....
https://www.babcox.com/editorial/us/us90126.htm
Which I am told is accompanied by low oil pressure.
DNK
DNK
Need to go back to Shawns. How do I diagnose this?
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
T Knock-Off Spinners Austin Healey 43
Michael Oritt Safety-wiring knock-offs Austin Healey 24
TomMull Knock Off Tool Restoration & Tools 6
R Knock Rover / Land Rover 1
S TR2/3/3A What a sad day. There is a knock at the door. Triumph 7
HighAltitudeTR3 TR2/3/3A Valve Knock Question Triumph 28
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Knock knock... what's this? Triumph 100
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
CJD TR2/3/3A Knock Off Differences Triumph 13
steveg Has anyone used a knock sensor? Austin Healey 0
Feathers Knock off wheels for sp250 Other British Cars 6
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
S Knock in Transmission/Gearbox Austin Healey 4
S Eared knock-offs - how tight? Austin Healey 19
H General TR Triumph Script Knock-Off Hub Cap Triumph 6
CJD TR2/3/3A Coarse Vrs. Fine Knock Offs Triumph 5
Healey Nut Knock off removal Austin Healey 3
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
J knock, off tools Jaguar 6
V Panasport Fake Knock Offs Triumph 8
RickB NFI - knock off tool $10 Spridgets 2
Westfield_XI Help, I need a knock off wrench Spridgets 17
Got_All_4 Wedge Searching for knock offs for TR7 wheels Triumph 2
britndablood Needed 1 two eared knock off RH side 12 tpi Austin Healey 3
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
L New Knock-off Spinners Austin Healey 21
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
UmmYeahOk Knock Offs - Whats the deal? Triumph 28
T Looking for used set of Knock off minilites Spridgets 4
prb51 Pinking, Knock, Plinking etc. Triumph 6
R engine knock/ping, retard ignition doesn't help Spridgets 49
kodanja Knock it off? Triumph 13
MadRiver Octagonal safety knock-offs MG 7
N Starting out in 1st gear knock or clunk Triumph 20
kodanja Knock off grease? Triumph 14
C Wire Knock-offs Triumph 9
jaybird I need to bribe someone or knock someone off MG 22
M Knock off's......or..... Fall off's MG 6
John Loftus Knock off lettering Austin Healey 14
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
TR4 Wire Wheel Knock Offs???? Triumph 13
EMGEBE TAT TAT TAT TAT TAT [engine knock?] MG 13
W knock off Austin Healey 7
R Best price for Minilite Knock-offs? MG 8
