TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What?
HighAltitudeTR3
i just finished work on my rod bearings, the crank looked to be I good shape and mic'd well within the range of wear. My original post (that concluded with replacing rod bearings that alleviated the knock from my engine. I mentioned that the sound would go away when the engine warmed up a bit. I believe that I was working on two problems and the rod bearings were half and this is the other half. I don't know where to start on this...
here you can hear the tick I'm talking about.
https://youtu.be/WY81QxtaAA4
it doesn't occur at idle as it fades completely when load is taken off the vehicle. You can hear my shift from two gears (I believe it's first and second). Where is a good place to start?
HighAltitudeTR3
HighAltitudeTR3
Thanks Tom, a lot of good info there. I'll start checking those things off my list.
Merlin63Tr4
You wrote previously that you were going to replace the exhaust manifold gaskets, did you get that done?
Have you checked the exhaust manifold for cracks?
M.
sp53
To me that sounds like a worse problem, like a rod bearing or wrist pin. What happens when the motor is warm and everything is at operating temp say a 1/2 hour of driving, and you open that MOTHER up to say 5.5 to 6K? Does it sound like the poop is going to hit the fan with thuds and rattles or just a wound tight motor?
Steve
CJD
Steve
That is along my train of thought. If the rod big end bearings were worn out, it is likely everything else is worn out to match. Sorry...just the way it works. Drive it until it becomes unbearable and plan to rebuild the entire engine when it does. Or, you can rebuild it one tick/knock at a time. You'll end up at the same place in the end!?!
HighAltitudeTR3
HighAltitudeTR3
So I took the car out for date night last night and before we left, I checked oil (good) checked coolant (1/2 qt low) and I tightened a bolt that was slightly loose on the generator. I hop in the car and *NO SOUND* at all!! Gone. Voodoo mechanics. After dinner, the noise was back, but at 1/3 the volume of before.
I checked the big end bearings and wrist pins for play and they are tight. I'm thinking it has something to do with the cooling system. Only because I've seen some relief before with the coolant being added (when I first got the car running, the heater was closed and didn't have coolant, once I opened it I heard that sound, added coolant it it got better). Doesn't make a ton of sense, anything in there that would love coolant this much?!
HighAltitudeTR3
HighAltitudeTR3
Oh and when I open it up it sounds perfect. I really only hear the rattle between 900 and 1200 rpm.
HighAltitudeTR3
HighAltitudeTR3
Well, I have to say I am starting to think the noise is actually a rattle. I am going to replace the engine mounts (needs to be done anyway) I have a feeling this is going to fix it. The way it comes and goes. I tuned the carbs and the noise almost went away, and it's not that it is silent.... it's intermittent. Also would explain why I can't pinpoint the noise with (makeshift) stethoscope. Just my Saturday afternoon idea. :smile:
mrv8q TR2/3/3A Tick, tick, tick. Triumph 0
T TR6 TR6 tick in first... Triumph 19
Nunyas It goes "tick tick tick tick tick..." MG 8
jaybird tick tick tick... MG 11
T TR6 tr6 engine tick Triumph 12
E Off Topic Useful for saving some cash maybe? MG 0
Basil Virtual Rally - maybe Other British Cars 0
Basil Virtual Rally - maybe TVR 0
Basil Admn Note Virtual Rally - maybe Triumph 0
Basil Virtual Rally - maybe Sunbeam (Rootes) 0
Basil Virtual Rally - maybe Spridgets 0
Basil Virtual Rally - maybe Rover / Land Rover 0
Basil Admin Note Virtual Rally - maybe MG 0
Basil Virtual Rally - maybe Lotus 0
Basil Virtual Rally - maybe Jaguar 0
Basil Virtual Rally - maybe British Motor Corp 0
Basil Virtual Rally - maybe Austin Healey 0
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
Mickey Richaud General MG Victor [Maybe] On Ebay MG 12
S TR2/3/3A tr3 maybe Triumph 7
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
bcliff MGB Are you looking for and MGB Roadster or maybe something else. MG 5
D TR4/4A unidentified, but maybe a manifold piece? Triumph 16
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
D TR4/4A flywheel bolts maybe too long Triumph 15
waltesefalcon Panteras, maybe Panteri? Spotted 0
B TR2/3/3A Another/maybe the same fuel delivery problem Triumph 5
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
B Maybe selling my Bugeye? Taking a poll - Spridgets 18
HealeyRick TR2/3/3A Maybe I'll Rethink being a Healey Guy Triumph 8
F Too much procrastination[maybe long winded] Austin Healey 9
KVH TR4/4A Want to Buy This one: For Maybe $50,000? Triumph 3
bugedd The journey begins....maybe Spridgets 9
RickB 5 speed or maybe clutch noises? Spridgets 28
M_Pied_Lourd Maybe I am just Slow..... Triumph 15
Jeepster Maybe I should sell my Healey and buy a boat? Austin Healey 9
KVH TR4/4A TR4 OD Maybe Last Question Triumph 2
RickB Maybe a new small 5+ speed trans-plant?? Spridgets 6
pkmh BJ8 Stalling Problems resolved [maybe??] Austin Healey 13
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
S old question maybe?, rebuilt engine Triumph 3
jsfbond Wedge TR7's for sale.......maybe? Triumph 4
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
V Dog? Maybe not Triumph 4
T Would this maybe be a better path to take? Restoration & Tools 15
Tabcon "Gone in 60 Seconds"....maybe. Jaguar 4
C A fuel problem, Maybe, maybe not Spridgets 22
P TR6 Maybe Selling a 76 TR6 Triumph 4
RickB MGC Maybe selling the 69 MGC GT - what's it worth? MG 39
