5 speed or maybe clutch noises?
RickB
My Midget has been making some strange noises, at first I'd hear a kind of a "ping" or "Tink" once in a while when starting out in a low gear. This has gradually evolved into some really bad sounding noises.
Sometimes like a steel pipe being dragged on the pavement.
Or like letting a screwdriver bounce on the spokes of a bicycle tire in motion.
The "Tink" sounds have increased.
This is mainly when under load, and in any gear now.
Is this most likely my pressure plate or TO bearing going bad?
Operationally things are fine, but the noises are bothersome.
RickB
RickB
That would sure be a lot easier to replace.
I need to jack it up and take a close look, but I don't feel any shaking or vibration when this is happening.
I fear the worst.
nomad
These transmission's aren't bulletproof. I have the midget that I drove to LoTO sidelined with something wrong in the 5 speed department.
The input shaft bearing occasionally gives trouble. Simple fix if it doesn't go out completely.
Kurt.
Billm
Rick
Do check those u-joints, they have been in there for a LONG time!
BillM
smaceng
Check to see if the front ujoint is hitting tunnel. I had that problem, and had to add spacers to the driveshaft at the diff to move the ujoint forward where there was more room....the sound was usually in first also.
Scott in CA
RickB
RickB
Strangest thing this morning, it was quiet under there!
I will get under and check it out, for the front yoke I need a Datsun U-joint right?
Bill - is there anything special about it?
Billm
I don't know if it is special- it is the one that you had in there from the beginning, we haven't changed it.
BillM
You could change it to the normal one that is commonly used, I have all of the parts.
Gerard
BillM
Paul used to tell me the original U-joints on the 210 were not replaceable. Not sure what's available today though.
RickB
RickB
Advance Auto lists some that "may fit"...
None found at NAPA, O'Reilly or Rock Auto.
nomad
I have a Datsun driveshaft on hand for the splined yolk. The Datsun U joints were not replaceable. They are permanently staked in to the yolks.
Kurt.
Gerard
Kurt.
That's what I thought...
RickB
RickB
That explains why none can be found.
:congratulatory: :playful:
Drove twice more with none of the noises.
I'm kind of waiting for something to fall off the car now, listening to all the odd little sounds it's producing.
RickB
RickB
It's stopped raining here so I jacked up the car and took a look.
Catastrophic failure is imminent.
I'll drive one of our other cars until I get this fixed.
Close up:
Jim_Gruber
Rick, The U -Joint and yolk but what exactly are we looking at for imminent failure? Missing retainer? Looks like something is in there.
RickB
RickB
In the second picture you can see the cup is fractured, there is of course a lot of play in there.
Jim_Gruber
Oh yeah, that's a problem. Good luck.
RickB
RickB
BillM is hooking me up with the right stuff!
nomad
Rick you have the absolutly stock Datsun drive shaft and U joints. When this was done the adaption to BMC must have been done at the Differential end. All the current kits make an adaptor for the Datsun drive spline sleeve to a BMC U joint and drive shaft. The easiest way would be to buy the drive sleeve/ U joint assembly and fit it to a spridget drive shaft.
Kurt.
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
RickB Maybe a new small 5+ speed trans-plant?? Spridgets 6
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
