Question on 1 speed wiper motor
Bayless
My '67 Sprite has a single speed (DR3 I think) wiper motor. I think I know how to figure it out but, before I let the smoke out, can someone tell me which terminal gets the green wire (#1 or #2)?
Mk3Sprite
I didn't note the colours down but terminal 1 gets the line from the switch which switches to the ground line. Terminal 2 gets the supply line from the fuse.
roscoe 5 speed conversion question Austin Healey 9
H Ford T9 5 speed question Restoration & Tools 1
HealeyPassion Question for 5 speed conversion guys Austin Healey 13
Bruce_B Rivergate 5 speed question..... Spridgets 2
Bruce_B Motor & trans are in..5 speed question for my BE Spridgets 1
budk1953 5 Speed Conversion Question MG 6
S 5 speed 210 conversion and shifter question? Spridgets 7
T Idle speed question Jaguar 2
O overdrive and 4 speed question? MG 1
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
