Idle speed question
Keoke
[ QUOTE ]
Hi, the idle speed for a v12 xjs is 750rpm but is this in park or drive?
[/ QUOTE ]
Better try Park its a might safer---Keoke /ubbthreads/images/graemlins/laugh.gif
John S Farrington
I like to set the idle speed at about 800 RPM while in park. A slight variation dedpending on your desire or the tuning of the engine is permissible.
crispy Idle Speed Variation Austin Healey 19
S Can’t get idle speed below 1300 RPM Austin Healey 28
NutmegCT T-Series MG TD idle speed? MG 12
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
wkilleffer MGB Air leaks and fast idle speed MG 11
S Idle Speed Setting versus Generator Output Spridgets 3
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
Anthony_S TR2/3/3A TR3a correct engine idle speed Triumph 8
M Adjusting idle speed Triumph 28
C TR6 69 TR6 idle speed continued... Triumph 2
C TR6 TR6 Idle Speed Triumph 5
ekamm Increasing Idle speed Triumph 4
R BJ8 + Novice. Idle speed adjustment help req'd. Austin Healey 5
B Idle speed for dynamic timing Spridgets 3
R Idle Speed Austin Healey 5
AUSMHLY idle speed Austin Healey 8
BoneIdle Idle Speed Drops After Fuel Filter Element Change MG 1
MadRiver Idle speed Triumph 7
Harry_Ward TR2/3/3A TR3 idle speed drop Triumph 7
wkilleffer Idle speed and engine temps MG 6
wkilleffer Vacuum advance and idle speed MG 11
D 1991 xjs v12 high idle speed. Jaguar 8
AltaKnight Idle speed adjustment Triumph 6
S Correlation between Idle speed and timing Triumph 5
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
HalLucy Post-War Other Renown - Idle too fast Triumph 5
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
