Idle speed
MadRiver
Bronze
Had an unusual idle speed issue today. I usually idle around 800 when the car is cold, and then around 1100 when it gets warm. I pull into the office today and for some reason I'm idling at 1500. I goose the engine, and it comes back down, but then creeps back to 1500. Not sure what's going on there. I'll check it out tonight on the way home, but any thoughts on that?
hondo402000
you might try plugging off vacuum lines and brake booster line, and see if that takes the RPM back down, I had a bad break booster and that caused erratic idling
middleagecrazy
Damper oil. Checked it lately? I had the same thing happen. Found that the oil needed topping off. Did it. Fixed It.
Wish it was always that easy.
Anthony
piman
Hello Bill,
why do your un such a high idle speed, 900 to a 1000 is fine cold but 700 is better hot?
Anthony, that's strange, the damper oil has no function at steady speed conditions?
Alec
jerrybny
You might be right but its a good idea anyways to always check you damper oil level. I do a check of oil level, brake fluid, clutch fluid, damper oil and coolant everytime before I take the car out. Of course mine only goes out on sunny days and never in winter. Just my 2 cents worth even though my wife will only give me a penny for my thoughts. /ubbthreads/images/graemlins/cheers.gif
MadRiver
MadRiver
Bronze
Howdy gang. Thanks for the posts. I'll check the oil level in the dampeners -- Haven't done that in several months. I've got a new servo, and haven't heard any of the hissing when they die, but I'll take a look anyway. Let's hope it's something minor. /ubbthreads/images/graemlins/cryin.gif
Musicman
Definitely check vacuum lines. A loose connection can easily mess with idle speed.
AltaKnight
Check that the small vacuum line below the carbs leading to the distributor is still connected, mine slips off sometimes and mirrors your problem when it does.
crispy Idle Speed Variation Austin Healey 19
S Can’t get idle speed below 1300 RPM Austin Healey 28
NutmegCT T-Series MG TD idle speed? MG 12
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
wkilleffer MGB Air leaks and fast idle speed MG 11
S Idle Speed Setting versus Generator Output Spridgets 3
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
Anthony_S TR2/3/3A TR3a correct engine idle speed Triumph 8
M Adjusting idle speed Triumph 28
C TR6 69 TR6 idle speed continued... Triumph 2
C TR6 TR6 Idle Speed Triumph 5
ekamm Increasing Idle speed Triumph 4
R BJ8 + Novice. Idle speed adjustment help req'd. Austin Healey 5
B Idle speed for dynamic timing Spridgets 3
R Idle Speed Austin Healey 5
AUSMHLY idle speed Austin Healey 8
BoneIdle Idle Speed Drops After Fuel Filter Element Change MG 1
Harry_Ward TR2/3/3A TR3 idle speed drop Triumph 7
wkilleffer Idle speed and engine temps MG 6
wkilleffer Vacuum advance and idle speed MG 11
D 1991 xjs v12 high idle speed. Jaguar 8
AltaKnight Idle speed adjustment Triumph 6
T Idle speed question Jaguar 2
S Correlation between Idle speed and timing Triumph 5
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
HalLucy Post-War Other Renown - Idle too fast Triumph 5
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
