Looking at the minimal emission system, I noticed that the PVC hose line is only connected to the front weber carb. As noted, the idle speed is much better now - 9500 rpm, after I replaced the diaphram. Do you think I need to put a tee in the line and connect both carbs? Is the blow by sufficiently exhausted as currently set up? Cheers to all.
