My tr6 wont idle. It hasn't since I bought it. Even after it is warmed up, if I pull up to a stop light I have to either rev the engine or pull out the choke to keep it from stalling. I keep reading on here that 99% of all carb problems are actually ignigtion problems, so can someone help me out. I should have the next few nights to try and get this working. With the choke out a little I can get the engine to idle around 1100-1200 rpms. I have borrowed a timing light and it is reading +21. I think my bently manual says I should be at +4. Am I right? My father who hasn't messed with the timing of a vehicle in over 20 years attempted to help me and we started to turn the distributer we were able to get the timing down +16 before the vacuum advance got in the way. When doing this, the engine actually started running worse, so we put it all back. Can someone help me with even where to start? Help me find TDC and go from there? I have checked all the plugs and they are gapped correctly and it does not appear I am running to rich or lean. The PO did install a Pertronix electronic ignition and I have the original ZS. The car runs great when I am not sitting still.
Please Help!
Please Help!
