Raising the height ona 1971 B......
saltshaker
Member
What is the best way to raise my 71 B just a little. I've got one suggestion of replacing the rear springs with a set from a GT... is this correct?
vping
Bronze
I used GT spring in my Roadster. No noticeable change in height and a much stiffer ride.
Michael Oritt Raising Ride Height Austin Healey 9
Got_All_4 TR2/3/3A 2 questions; raising the body and taking out that lean to the right Triumph 12
M Raising the car without a lift Triumph 14
M Engine Oil Leek Raising Some Concerns Spridgets 2
S Raising a 71 MG 4
Sarastro Cool idea for raising the car Restoration & Tools 14
S Raising the Rear Austin Healey 1
C MGB-GT Ride Height MG 7
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
torque-drive MGB SU HS4 jet height adjustments MG 6
Pythias Springs and ride height... Questions. Spridgets 2
steveg TR6 Spec needed for correct ride height Triumph 28
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
dklawson GT6 Float Height, 150CD [Early CD, Not Later CDSE or CD2SE] Triumph 7
Bremer TR2/3/3A Block deck height? Triumph 10
Michael Oritt Ride height Austin Healey 20
J front cross member height from bottom to floor on BJ8 Austin Healey 5
A Throttle Pedal Height Austin Healey 17
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
B TR6 TR6 clutch pedal height Triumph 2
H 1/4 elliptic ride height Spridgets 1
J TR2/3/3A TR3 coil spring height Triumph 4
BlueMax Bugeye Ride Height? Spridgets 4
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
Rob Glasgow Uneven frame height Austin Healey 18
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
58Custom Ride height issue, spring help Spridgets 8
RJS TR4/4A TR4A Stock Ride Height Triumph 5
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
K SU float bowl....measuring the height? Triumph 13
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
T 100 Ride Height Austin Healey 1
richie TR4/4A TR4a live axle - Height adjustment Triumph 7
B TR2/3/3A TR3A Seat Height? Triumph 2
C Setting bonnet height at front? Austin Healey 8
rjc157 rear spring height Austin Healey 10
S BJ7 Ride Height Austin Healey 7
S Spitfire 76 spitfire leafspring height Triumph 2
I Bugeye height adjustments? Spridgets 19
AUSMHLY Float bowl fuel height BJ8 Austin Healey 4
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
Jim_Gruber Spring height Spridgets 12
Zimmycobra TR4/4A TR4A Front ride height revisited Triumph 24
PatGalvin TR2/3/3A TR3A Ride Height Triumph 5
T TR4/4A TR4a ride height question Triumph 17
J Bugeye rollbar height Austin Healey 2
