I have put the front suspension and rear suspension back on the car. The rear is where it going to be. I did not put anything new on the car, all are original, all but the sway bar which is DWR. Just powder coated and painted the A arms, springs, trunions.
I did a search, but did not come up with anything about how to set the front height up. I did see something about putting a 2 inch block under the A arms, but I think that was to keep the weight off the front bump stops.
The engine and transmission are all in the car. I looked in the 100 service manual, but I did not see anything about adjusting the height.
I also put in a Denis Welch sway bar (front) but it had no directions as to setting the bar. Do you just put the weight on the front and tighten the nuts?
Thank you in Advance,
Tod
Tod
