TR4/4A unidentified, but maybe a manifold piece?
Dash
Unfortunately I didn't take a pic of the manifold before I took it off as it was just some studs, clamps and nuts. However the little piece in the photo was in the bag I marked as manifold stuff but I just don't remember this piece nor can I find it in any diagram. Does anyone recognize this as belonging somewhere on or near the exhaust manifold?
Since the lifting bracket is only slotted, I was thinking maybe it fits over the bottom rear stud and the ear on the piece hooks the lift to help keep it from twisting, otherwise, I'm stumped..
btw, the raised ring is a washer and not part of the main piece but it goes there..
Popeye
Bronze
I don't recognize it, and could not find a similar part in my photographs.; TR4A engine disassembly. Sorry! I don't recall something like that, and I took my manifold off about 9 months ago.
Merlin63Tr4
Not part of the intake/exhaust manifold system.
M.
Geo Hahn
...Since the lifting bracket is only slotted, I was thinking maybe it fits over the bottom rear stud and the ear on the piece hooks the lift to help keep it from twisting...
I do not recognize it either, but I have to say: I like that explanation.
Dash
Evidently this little piece ended up in the wrong parts bag..aaargh! A tough little piece to cypher but I guess I'll eventually find it's home as most of the car is still scattered al over the garage. Thanks for confirming where it doesn't go. At least I can keep going forward with the current phase of the project.
gbtr6
I'll hazard a guess. It looks a little like the piece that goes in between the fuel bowls and body on an SU HS6 carb. They are used to angle the bowl on the carb. Possibly.
Perry
Dash
Think I found the home for that piece..It locks the generator link arm where the arm attaches to the water pump housing. See photo..
Merlin63Tr4
Sorry Dash, but no.
The locking tab you speak of has four "legs"
Two are bent up two sides of the bolt head that goes thru the generator link and lock it in place.
And the other two are bent in the other direction down two sides of the link arm so that the locking tab is locked in place.
M.
p.s.
Ref item 16A
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29116#16a
Merlin63Tr4
Yeah, not quite the same.
Actually, I think only 3.
Easier to see in this graphic:
Sorry Geo, was working from memory...
I removed the original long ago.
On the other hand, the replacement I made does have four legs.
I refused to pay the amount of money that the usual sources want for this simple lock tab....
M.
Dash
Oh darn, so close..thanks guys, I'll keep hunting. In the meantime I'll have to get a 16a.. It does appear however that my mystery piece may have a similar application although I'm running out of options to anything associated w/the engine.
Dash
I've tried to be careful about keeping track of the small stuff like this but this little piece had a mind of it's own and crawled into a bag where it didn't belong. After 8 months into this project and having to correct, fix, or replace one thing after another, most of which doesn't seem to focus on the big stuff, I just don't remember this thing. Good news is that it's definitely meant for external use vrs something within something so hopefully I'll stumble on it's purpose eventually or who knows, I may end up with a whole grocery bag full of this kinda stuff before I'm done.
Reminds me of many years ago when I overhauled another tractor block: first time I had ever done one so had no idea what I was doin. This one is #2 and I still don't..ha.. Anyway, when I was done I had parts left over. I was actually scared to start the thing thinking I had forgotten to do this, that, or the other. Well finally got my nerve up to crank it and it turned out to be the best running ( old used) engine I ever owned. Beginners luck I suppose. I remember joking about why they would put stuff in an engine if it didn't need it..
malbaby
Perhaps it is a semi locking device that is fitted to one of the RHS bell housing bolts that is very hard to access...cannot remember which one exactly, but I welded a tab on the head of a bolt that had limited access.
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
SherpaPilot TR6 Unidentified Bulb Triumph 7
R TR4/4A Tr4A, unidentified wire in steering wheel area Triumph 4
J Help with unplugged unidentified wire please. MG 5
mgnewbie unidentified nipple... MG 57
J unidentified car-- need help Other Cars 6
E Off Topic Useful for saving some cash maybe? MG 0
Basil Virtual Rally - maybe Other British Cars 0
Basil Virtual Rally - maybe TVR 0
Basil Admn Note Virtual Rally - maybe Triumph 0
Basil Virtual Rally - maybe Sunbeam (Rootes) 0
Basil Virtual Rally - maybe Spridgets 0
Basil Virtual Rally - maybe Rover / Land Rover 0
Basil Admin Note Virtual Rally - maybe MG 0
Basil Virtual Rally - maybe Lotus 0
Basil Virtual Rally - maybe Jaguar 0
Basil Virtual Rally - maybe British Motor Corp 0
Basil Virtual Rally - maybe Austin Healey 0
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
Mickey Richaud General MG Victor [Maybe] On Ebay MG 12
S TR2/3/3A tr3 maybe Triumph 7
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
bcliff MGB Are you looking for and MGB Roadster or maybe something else. MG 5
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
D TR4/4A flywheel bolts maybe too long Triumph 15
waltesefalcon Panteras, maybe Panteri? Spotted 0
B TR2/3/3A Another/maybe the same fuel delivery problem Triumph 5
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
B Maybe selling my Bugeye? Taking a poll - Spridgets 18
HealeyRick TR2/3/3A Maybe I'll Rethink being a Healey Guy Triumph 8
F Too much procrastination[maybe long winded] Austin Healey 9
KVH TR4/4A Want to Buy This one: For Maybe $50,000? Triumph 3
bugedd The journey begins....maybe Spridgets 9
RickB 5 speed or maybe clutch noises? Spridgets 28
M_Pied_Lourd Maybe I am just Slow..... Triumph 15
Jeepster Maybe I should sell my Healey and buy a boat? Austin Healey 9
KVH TR4/4A TR4 OD Maybe Last Question Triumph 2
RickB Maybe a new small 5+ speed trans-plant?? Spridgets 6
pkmh BJ8 Stalling Problems resolved [maybe??] Austin Healey 13
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
S old question maybe?, rebuilt engine Triumph 3
jsfbond Wedge TR7's for sale.......maybe? Triumph 4
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
V Dog? Maybe not Triumph 4
T Would this maybe be a better path to take? Restoration & Tools 15
Tabcon "Gone in 60 Seconds"....maybe. Jaguar 4
C A fuel problem, Maybe, maybe not Spridgets 22
