Transmission Clicking
rusty55
I took the TR3 out for a drive this morning. A few miles in, I noticed a clicking when in 1st gear. Also happens in reverse. All other gears are quiet. Car drives normal but the click is worrisome. Any ideas or thoughts would be great.
TR3driver
Great Pumpkin - R.I.P
Be afraid, be very afraid.
bgbassplyr
Sounds like a chipped tooth on the 1st-reverse gear.
Had this happen to my first TR3, drove it for a couple of years with no further problems.
Drain the oil from the trans and if the tooth (or chip) doesn't come out with oil, fish around in the trans with a magnet. Once it comes out and you don't push 1st too hard, all will probably be ok.
OR
rebuild the trans and replace the broken gear.
There are only two options to be considered.
donbmw
OR
Had the same thing happen earlier this year.
Don
HerronScott
That's what happened with the TR3 overdrive I put in my TR4A when I restored it as well. :frown:
Scottt
TomMull
Not very often we get concurrence like this. I guess that's what happens when you muscle that non synchro gear enough.
Tom
CJD
The funny part is the warning in the "tips" manual not ot downshift to 1st above 15 MPH...! More like 1 MPH.
John
TomMull
Heel and toe, match the revs and double clutch will work about 50% of the time at 15 mph, after you get good at it. The other fifty breaks the bits off the gear.
Tom
R
rusty55
Well, I guess that's the answer. No question. I'll drain it and check it.
Thanks
Afrodesia
I have the same thing. Must be common as I remember my dad's doing the same thing. Not looking forward to that eventual fix = \
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
A TR6 Installing differential and transmission Triumph 10
PAUL161 T-Series 5 Speed Transmission MG 85
PAUL161 T-Series Replacing Transmission MG 3
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
R TR2/3/3A Transmission Service TR-2 Triumph 58
Spock TR6 Transmission Plug Triumph 4
