My U Joints are clicking away
Dadandson
I need to replace the U joints on my 74 1275 Midget. Will I need to drain the transmission first? How much difference is there between Hardy Spicer brand and aftermarket parts? I have replaced U joints on other cars but I would like to ask if there are any little bits of wisdom on a Midget. I have read that lining up the spline can be tricky because of the tunnel. Masking tape?
jlaird
Do not drain tranny, not necessary. Jack up the rear. Unbolt the shaft at the differencal, four bolts and drag the thing out.
To put it back, with duct tape tape the front universal straight in line with the shaft and poke it in, might take a few trys but it will go nicely. Reattach the rear with the four bolts and you are good to go.
Have the new universals installed by your friendly machine shop. In my opinion a few bucks is well spent there, make sure they understand the front universal greese plug is supose to point toward the rear.
Dadandson
Dadandson
Thanks Jack. How about quality? I found them at my local Autozone for $11 each and in stock!
jlaird
Prob as good as any, I'd use em.
Dadandson
Dadandson
I cannot express how grateful I am for your experience and more importantly, you willingness to share and help. Thanks
jlaird
Gesh Tim. That's what we do here. One for all and all for one. Just a bunch of electronic friends helping friends as best we can.
Scott_Hower
Amen to that.
edit... Jack, I sent you a book a while ago on WWII aviators, what did you think of it and did you pass it along?
jlaird
Scott, I don't think I got it. At least my old brain is not remembering at the moment.
Just checked, if it was hardback I did not receive it.??????????
Dadandson
Dadandson
Mission accomplished. What a difference new U joints make!
Scott_Hower
Paperback ... "Deadly Sky"
Check PM for the link...
jlaird
Ahh, will inventory but don't think I got it.
Oh god I found it. It fell behind the books on the book case.
Will read and report and I think Doc is next is he not?
Dadandson
Dadandson
Piece of Cake! The U joints were $8.99 each at AutoZone and Pep Boys installed in the drive shaft for a $20 bill. It is amazing how all the minor vibration went away. I have been playing around with the front end and it turned out to U Joints.
jlaird
Well done Tim, not too bad a job is it.
Dadandson
Dadandson
I did not need duct tape as there is a hole in the tunnel that I used to line up the spline end of the shaft. One of the easier things I have done to the car.
jlaird
You know why it is so easy, Only needs to be done once in a life time.
B TR6 replacing U joints Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
Bugeyze Universal joints Spridgets 6
R Moss permanently lubricated U-Joints Austin Healey 1
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
D TR6 U-joints Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
AngliaGT TR6 TR6 U Joints Triumph 3
Foura TR4/4A Steering column Universal Joints Triumph 10
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
RickB Crimped in U-joints? Spridgets 7
6TTR3A TR6 Replacing the IRS u-joints on a TR6 Triumph 15
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
sd80mac7204 Universal Joints Triumph 3
RJS Greasing U-joints Triumph 13
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
mikecyc72usa Oh the fun of U-joints Triumph 19
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
M Broken Ball Joints Spridgets 14
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
King_of_England Ball Joints and Mini ID British Motor Corp 7
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
Tabcon Ball Joints and mushy rubber Triumph 7
Z Dive Shaft Uni Joints Austin Healey 10
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
bigjones Ball Joints - does this look right to you? Spridgets 12
mrv8q TR6 TR6 carb "ball joints" Triumph 10
N grease for rear axle sliding joints Triumph 14
svtmikey Un-joints - I don't remember them being this hard! Triumph 29
L Tightening U-joints Restoration & Tools 3
dklawson TR6 U-Joints Comparison, TR4 vs. TR6 Triumph 3
G TR5/TR250 NAPA U joints fro TR250/6 Triumph 5
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
A TR6 Jag ball joints donot work on TR6!! Triumph 5
V TR6 A TR6 with Jag ball joints Triumph 27
2 U Joints Triumph 4
D Crappy U-joints Triumph 20
T steering u-joints???? Triumph 1
S S-Type Bad Ball Joints, Control & A Arms Jaguar 19
G Has anyone uprated the rear axles to CV joints? Triumph 47
G replacing the u joints - shipfitters disease Triumph 9
tr6web TR6 Rear hub u-joints TR6 Triumph 9
KVH Tie Rods and Ball Joints Triumph 5
TR4 TR4/4A Changing universal joints in a TR4???? Triumph 5
M U-joints- quick question Austin Healey 5
