TR4/4A Changing universal joints in a TR4????
TR4
Just thought I would ask this before I do something I shouldn't. How hard is it to change universal joints in a TR4? Getting the drive shaft out, switching the universals and putting it all back together. Mine is starting to clunk when you let off the gas or go from forward to reverse. I am a novice mechanic so please tell of all to watch out for. Your advice is greatly apprecitated.
dan_k
removing the driveshaft isn't a problem just remember to mark the flanges so it goes back together the same way.
TR4
TR4
I was told that the drive shaft can only be removed by taking out seats, carpet and the tunnel cover then going at the forward joint from above. I looked last night from underneath and it does look tight. Can it come out from underneath without all that interior work?
Alan_Myers
Hi,
Yes, you do have to remove at least one seat, the center dash brace, carpet and the gearbox cover. (I've seen modified, two-piece covers that make it a little easier, but would assume you have a one-piece cover.) It is impossible to get to the nuts and bolts from below. In fact, they are hard to get at in any event, you'll probably need to use open-end wrenches on them.
In fact, during regular service you need to be able to access the front u-joint from above - via a large rubber plug near the rear of the gearbox cover - to grease the u-joint. This doesn't require a lot of disassembly, but also doesn't give enough access to allow removal of the nuts and bolts.
If your drive shaft is clunking, it could be the u-joints or it's also possible the old nuts and bolts have gotten really loose. I found 6 of 8 were less than finger tight on my car not too long ago. Pretty scary, the thought of a drive shaft coming loose on the road and flailing around.
The original nuts were Nylock, and really shouldn't be reused in this application. At the very least, buy eight new 3/8" NF Nylock nuts.
I highly recommend going a little further and getting an upgrade bolt and nut kit that The Roadster Factory offers. It includes all-metal self locking nuts and grade 8 bolts. I found the bolts provided a little long for comfort at the diff and cut them down a few threads to increase clearance slightly. I also used Locktite on them just to be sure.
If you find the old bolts loose, the u-joints should probably be replaced as a precaution. The front splined section can be removed for cleaning, but must be re-installed in the correct orientation. There are arrows stamped into both front and back sections of the drive shaft that should match up when done. Inside the cup that screws on and holds the front drive shaft section to the rear is a cork grease seal that often falls apart during disassmebly. It's not available from any of the major TR vendors, but there was discussion here about it in the past and someone mentioned a source. I ended up making a seal out of sheet rubber that seems to work.
It's not a bad idea, too, to have the rebuilt drive shaft professionally balanced. You can probably find a local shop to do this.
There has been some discussion of good and bad quality u-joints in the past, so you might look in the archives of this forum. I fitted greasable ones, G&K if I remember correctly. Not sure where I got them, though. They had been on my shelf for 4 or 5 years.
They seemed well made and fitted nicely. The factory manual was helpful fitting them. Someone mentioned not using a hammer, probably good advice but unfortunately I didn't really have a choice when removing the 25 year old, non-greasable u-joints from my car! I was very careful to avoid damaging the yokes in any way.
Hope this helps!
Alan
TR4
TR4
Thanks so much for all this detail. This sure lets me plan on how long the job will take. I really appreciate you sharing your experience.
Phil
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
T Kilmartin Changing Ownership Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 Changing Lock Barrels Austin Healey 15
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
bobh Changing Transmission Oil in 10 minutes Triumph 8
P CHANGING TO FRONT DISCs Spridgets 22
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
theleisure Changing Out Front Bushings Spridgets 5
R Changing Motor Mounts Triumph 6
BritcarsUSA Changing 5/8 to 3/4 Midget filter adapter nipple? Spridgets 4
rchakr Changing Rear Springs Triumph 6
beaulieu changing an old car to E85 Restoration & Tools 14
T Changing fluids Triumph 16
G Changing bearings Triumph 7
B Changing to Silicone Brake Fluid Spridgets 18
G Changing Horses in Mid Stream.... Triumph 47
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
T Changing front bolt pattern? Triumph 9
19_again changing right angle drives MG 1
G Changing my Sway Bar Triumph 11
