Shock oil
Guinn
My '78 squeeks when I get in or out. It shouldn't be excessive weight as I only weigh 156. I think it might be that the left shock is low on oil but have not checked it yet as it is too cold in my "garage". Any ideas? Also, what oil to use. Somewhere I read that the shocks take 20wt motorcycle fork oil. Why not just 20wt?
Bugeye58
Guinn, I believe that fork oil is specified because it has additional anti foaming agents not present in regular 20wt. Original Armstrong shock oil is also available from various sources.
Dry bushings could also be the cause of a squeak.
Jeff
Guinn
Guinn
I learn something every day! Anti foaming sounds like the reason for fork oil, alright.
Dry bushings? That also sounds like a possibility. What to do about that?
Dave Russell
Yoda - R.I.P
Guinn,
A quick fix is to squirt some brake fluid on the bushing. Most other lubes will cause the rubber to deteriorate. This "fix" doesn't last too long & needs to periodically renewed.
Guinn
Guinn
Thanks, both of you. Will put these ideas in my "to do" folder. My "garage" is too small and too open to do much until the weather warms again! I'd show you a picture, but haven't figured out how to do it yet.
G Right-Side Shock Weeping Oil Austin Healey 1
Celtic 77 General MG Lever shock oil refiller MG 0
AUSMHLY Lever Shock Oil Level Austin Healey 41
Raymond General Tech Shock oil MG 4
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
K TR2/3/3A Harley Davidson shock oil for Lever shocks? Triumph 3
L Oil under left front shock Austin Healey 7
Sarastro What do you use for shock oil? MG 17
Jeepster Shock absorbers oil level. Austin Healey 6
S TR2/3/3A tr3 Shock oil leaking Triumph 2
L Oil for Shock Absorbers Austin Healey 1
BOBBYR Shock Oil????? Austin Healey 3
J lever shock oil Triumph 7
M damper [shock] oil MG 6
Wana Shock Absorber Oil Level [was "Oh No!"] Austin Healey 12
PAUL161 Tony, Doc, Question on shock oil type MG 11
S Shock Oil Restoration & Tools 10
G Squeaking Armstrong Shock Absorber Austin Healey 7
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
Boink Ugly Shock Failure Spridgets 3
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
C MGA Shock fluid MG 14
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
John Turney Left Rear Shock Mount Austin Healey 5
R Shock Absorber Austin Healey 0
Griz Shock failure Austin Healey 4
S TR6 TR6 shock links Triumph 10
G TR4/4A Front Shock Install Triumph 14
