TR6 Armstrong Shock Colors
Got_All_4
Cleaning up my shocks for my 69 TR6. What color should the body be and the lever arm? Mine were so corroded I couldn't tell. Trying to keep it as close to original.
M_Pied_Lourd
Pigott in the Collectors Guide says Black, Silver and Natural....not much help.
Usually what I do is keep the body natural or silver and paint the arm black.
Cheers
Tush
Rut
I’m with Tush...natural aluminum body and black arm and it’s the same on the MGB and Bugeye. If the body is really corroded I would use a cast aluminum paint.
Rut
G Squeaking Armstrong Shock Absorber Austin Healey 7
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T Function - Armstrong Lever Arm Shock Spridgets 2
T Filling an Armstrong Lever Arm Shock Spridgets 0
T Filling for an Armstrong shock Spridgets 1
R question on filling rear shock....[armstrong] MG 3
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
K TR2/3/3A Armstrong Lever Shocks Triumph 5
J Armstrong adjustable lever shocks Spridgets 11
AngliaGT Armstrong Siddley Parts Car Other British Cars 3
S 1953 Armstrong-Siddley Sapphire Other British Cars 5
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
glemon What do you put in your Armstrong lever shocks? MG 12
Z Girling/Armstrong lever arm shocks Spridgets 2
T Armstrong dampers - always replace in pairs? Triumph 3
Jayrz Armstrong Dampers Spridgets 10
Luke_Healey How to refill Armstrong shocks? Spridgets 34
tony barnhill 1953 Armstrong Siddeley Sapphire on ebay Other British Cars 0
Daimlerdb18 Armstrong-Siddeley - to buy or not to buy? Other British Cars 29
G Right-Side Shock Weeping Oil Austin Healey 1
Celtic 77 General MG Lever shock oil refiller MG 0
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
Boink Ugly Shock Failure Spridgets 3
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
C MGA Shock fluid MG 14
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
AUSMHLY Lever Shock Oil Level Austin Healey 41
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
