TR2/3/3A Armstrong Lever Shocks
karls59tr
Bronze
Is it possible to check if a lever shock is working effectively when it's off the car? If they are the original shocks would it be reasonable to assume that they would be worn out after 50 years and that they should be replaced with rebuilt units? Anyone bought lever shocks from Nosimports on Ebay for $77.00 US with $30.00 refundable core charge?
Don Elliott
I'm still driving my TR3A with the original rear lever shocks from new in May, 1958. I restored the TR from 1987 to 1990 and at that time I drained the oil from my shocks and replaced it with genuine Armstrong lever shock oil. Since then I've driven another 113,000 miles with no issues. These shocks have been on my TR for 194,500 miles from new. Why change them. ?
Reminder:- if they are off the car, re-fill with the shocks standing up in the correct vertical position as they would be when mounted on the car. This is to avoid over-filling.
If the lever moves as it should - resistance in one direction and a quick return in the other direction, they are operating as they should.
6TTR3A
Try Googling resistance measurement for Armstrong lever shocks
Lots of info, Pretty negative to your question about "bench"testing.
FRank
TR3driver
Great Pumpkin - R.I.P
My take: Change the oil, then mount the shock upright and cycle the lever a few times to work the bubbles out of the cylinders. Double check the oil level and add more if necessary. Then force the arm through a full stroke up and down. You should feel the same resistance throughout each stroke (though not necessarily the same between up and down). If you can feel places where it moves easier or harder, the shock is worn out (or damaged).
As the Moss article notes, this is not a complete test, and certainly not grounds for evaluating performance or comparing one shock to the other. But, if they flunk this simple test, they are definitely bad. And if they pass, they are probably OK, IMO.
https://www.mossmotors.com/graphics/products/PDF/980-341.pdf
That eBay seller I believe is Peter Caldwell at World Wide Auto Parts in Madison, WI. He has been rebuilding them for a long time and I've never heard any complaints about the results. If you poke around on their web site, I think there is even an article on what all they do as part of the rebuild process. The result should be literally "better than new", even if you don't go for the various extra cost options (like increased damping, adjustable damping, etc).
https://www.nosimport.com/Lever-shocks-remanufactured/triumph-tr3-tr4-lever-shocks
I've got a pair packed up myself to go to him, just haven't sent them off yet. You need to contact him first, to get the instruction form and packing slip. He also offers options like immediately shipping rebuilt units from his stock, or waiting until your units can be rebuilt (for the true purists); and how much paint to apply afterwards (none, primer, arm only, entire shock).
Rut
I used Peter Caldwells shocks on my MGB and Bugeye Sprite and will on the TR4a...they are that good. As said many times they are rebuilt to better than new and have a lifetime warranty, they transformed the way my MGB drives.
Rut
PAUL161
Rut
I totally agree with having the shocks rebuilt by Peter! I had the shocks on the 72 B rebuilt by him and also the front shocks on the TF. His work is excellent and beyond compare. JMHO. PJ :encouragement:
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
J Armstrong adjustable lever shocks Spridgets 11
glemon What do you put in your Armstrong lever shocks? MG 12
Z Girling/Armstrong lever arm shocks Spridgets 2
T Function - Armstrong Lever Arm Shock Spridgets 2
T Filling an Armstrong Lever Arm Shock Spridgets 0
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
G Squeaking Armstrong Shock Absorber Austin Healey 7
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
T Filling for an Armstrong shock Spridgets 1
AngliaGT Armstrong Siddley Parts Car Other British Cars 3
S 1953 Armstrong-Siddley Sapphire Other British Cars 5
T Armstrong dampers - always replace in pairs? Triumph 3
Jayrz Armstrong Dampers Spridgets 10
Luke_Healey How to refill Armstrong shocks? Spridgets 34
tony barnhill 1953 Armstrong Siddeley Sapphire on ebay Other British Cars 0
Daimlerdb18 Armstrong-Siddeley - to buy or not to buy? Other British Cars 29
R question on filling rear shock....[armstrong] MG 3
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
Celtic 77 General MG Lever shock oil refiller MG 0
shadowfever Seat runner with lever Spridgets 2
Gliderman8 TR6 Lever shock noise Triumph 18
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
RJS General TR Lever Shock - HD Shock Valve Triumph 2
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
K Missing spring clutch release lever Other British Classifieds 1
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 2
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
R TR2/3/3A Transmission Lever Assembly Triumph 9
J BN2 Shift Lever Bushing Replacement Austin Healey 6
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
AUSMHLY Lever Shock Oil Level Austin Healey 41
C TR2/3/3A Rotating shift lever Triumph 12
