TR2/3/3A Rotating shift lever
cdharter3
My early (56) TR3 has a shift lever that will rotate. Once it rotates, i can no longer shift except into 1st gear. I have to think there is something like a bolt or pin at the base of the shift lever that stops it from turning in its socket. This may be obvious if I remove the cap holding the lever, but we all know about the number of things that need to removed from the interior to get to the bottom of the shift lever. Any insight is appreciated.
TR3driver
Great Pumpkin - R.I.P
Right, should be a long bolt that goes through the shift lever and both sides of the cap and extension, which holds it straight. Bolt should be obvious if you just remove the rubber boot.
Is there any chance you have a later gearbox fitted (or the top cover from one) with a TR3 lever installed? Later cars (starting with TR5/250 IIRC) used a different arrangement, with pegs and slots rather than the bolt all the way through. An early lever in a later top cover might cause your symptom.
Merlin63Tr4
C
cdharter3
I didn't even think about just removing the rubber boot. Great idea. And yes, it appears i don't have that bolt installed. I will check it out. Thanks much!
C
cdharter3
Regarding parts 10 and 11, my impression is that those are parts that were added (via engineering change) just after the production of my car. They were obviously added to stop the lever from rattling in its socket. And yes, mine rattles. I bought the parts to eventually install at some later date. Perhaps that later date has arrived. I assume I will need to drill and tap a hole for the spring and screw.
STeve 1958
It has been discussed on here that adding a short length of rubber hose under the cap will tighten thing up and stop the rattle.
sp53
I would say if the shifter goes all the way around then the shifter is busted. The narrow section on the bottom keys into the leakage with flat side, and I do think it will go around and around if it is in one piece still. I could wrong. Being broke would also not let the car shift into other gears, my guess.
TR3driver
Possible, if you have an early car. They were introduced at TS9593 according to the SPC. The whole shift lever changed at the same time.
Kind of tricky to add that hole, IMO, get the depth and angle just right. Strikes me as easier to just find a later shift lever.
It's not tapped, though.
I would probably try the rubber hose first (which was factory recommended), along with lots of heavy grease.
C
cdharter3
I am very intrigued by this "rubber hose" idea, but not clear on how that would be applied. Any details would be appreciated.
TR3driver
M Rotating the crankshaft by hand Triumph 35
TR6oldtimer Pushrods not rotating Triumph 2
J Rotating structure for the frame? Austin Healey 4
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
S MGB 78 MGB cannot shift into reverse MG 3
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
S TR2/3/3A Gear shift knob Triumph 8
WHT Center-Shift Bellhousing Austin Healey 10
DrEntropy Shift rod seal in an automatic? Jaguar 7
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
C For Sale Brown Ebony Shift Knob Other British Classifieds 0
TomMull TR2/3/3A shift knob Triumph 19
J BN2 Shift Lever Bushing Replacement Austin Healey 6
J TR2/3/3A such strange thread on gear shift knob Triumph 12
D 62 center shift gearbox Austin Healey 11
AUSMHLY Wooden shift knob, how to refinish Austin Healey 35
RAC68 First Gear Shift Difficuties Austin Healey 3
D 1962 center shift gearbox cover Austin Healey 7
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
F Austin Side shift transmission question Austin Healey 0
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
HealeyRick 2=3 Shift Spridgets 9
C TR6 Shift lever Triumph 4
J BN2 shift bushing replacement Austin Healey 5
U Shift knob reference? Restoration & Tools 11
S 1962 BT7 transmission shift rail bumber in bell housing Austin Healey 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
S TR4/4A Fascia support and shift rod boot Triumph 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
wangdango BJ8 gear shift consol restoration... Austin Healey 9
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Zitch TR4/4A Who said the TR4 round shift knobs were NLA Triumph 4
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
tinman58 TR5/TR250 Funny sounds from gear shift Triumph 4
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
T MGB My '80 B used to shift fine MG 2
