Shock failure
Griz
Just discovered that one of the brand new shocks on my BJ7 has failed. It appears that over pressurization has blown a hole in the casing of the left hand rear shock. I've nearly completed the restoration, just the convertible top remains to be installed, and have been driving the car around the area on 30-40 mile trips to see how things are working. Nothing major so far, except the shock issue. I've got less than 100 miles on the car so far. Has anyone else had problems with these replacement shocks?
FYI, I pulled out the old shock that came off the car, and it too had a hole in the same place!
Griz
Boink Ugly Shock Failure Spridgets 3
G Right-Side Shock Weeping Oil Austin Healey 1
G Squeaking Armstrong Shock Absorber Austin Healey 7
Celtic 77 General MG Lever shock oil refiller MG 0
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
C MGA Shock fluid MG 14
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
AUSMHLY Lever Shock Oil Level Austin Healey 41
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
Raymond General Tech Shock oil MG 4
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
John Turney Left Rear Shock Mount Austin Healey 5
R Shock Absorber Austin Healey 0
S TR6 TR6 shock links Triumph 10
G TR4/4A Front Shock Install Triumph 14
G BJ-7 Rear Shock Link Austin Healey 2
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
T TR2/3/3A How important are matching rear shock links? Triumph 9
maxwedge5281 front shock absorber mounting Austin Healey 3
Sarastro TR4/4A Shock aborber recommendations Triumph 6
T Tube shock conversion BJ8 Austin Healey 6
D TR4/4A stubborn lever shock link Triumph 2
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
T Function - Armstrong Lever Arm Shock Spridgets 2
T Filling an Armstrong Lever Arm Shock Spridgets 0
