TR4/4A Shock aborber recommendations
Sarastro
Of course, I mean shock absorbers. Can't edit the title, apparently, to fix my lousy typing.
I'm nowhere near the point where I need to buy shocks for my TR4A restoration project, but if I can figure out what I want, I can watch for them to go on sale. As time goes on, I'll probably be asking about other things, prematurely, for the same reason.
There seem to be quite a lot of options. VB has Woodhead, one of several original equipment makes. There are also offerings from Gaz, Spax, Koni, KYB, and some no-name options. Most of the latter, boutique brands, are a lot more expensive. KYB isn't too expensive, but I had a set of them on my Porsche, which were awful. I replaced them with Bilsteins, and the improvement was huge. So, I'm a little reluctant to use them. Koni is always a safe option, but expensive.
Anyone have an experience or recommendations?
Foura
I have Konis all round on my 4A - telescopics at the back. I also have them on the 1995 Commodore and I had them on the 1988 Commodore Turbo. They can be a bit firm initially but they seem to settle after a couple of thousand miles. It may not be a concern on a TR but they had done around 150k miles on the Turbo when I sold it and they have done a similar mileage on the V8 and they are still in excellent condition. You get what you pay for.
You may need to consider the springs that you are running. I have 390 lb/in springs on the front and Goodparts 470lb/in on the back. The stronger springs probably need a stronger shock.
Sarastro
Sarastro
Thanks for the suggestions.
I'm going to keep the car largely stock, as it is now, so I'd prefer not to start replacing springs. I also want to keep the lever shocks in the rear. Would the the Konis be too hard in that case? I kinda lean toward them even though they are a tad pricey, as they are universally recognized as a first-rate product.
martx-5
Would the the Konis be too hard in that case? ...
The Konis are adjustable. The problem is, you have to remove the shock to adjust it. Other adjustables, such as the Spax or GAZ, can be adjusted while in situ.
poolboy
I have Koni on the front of my TR6..they were on there when I bought the car. Like a lot of TR6 owners, mine are set on the lowest (softest) setting.
If they ever do wear out, I don't think I'll pay for replacement adjustable shocks.
Sarastro
Sarastro
Thanks. Yes, I was aware they were adjustable, but I was concerned that they might be too hard even on the softest setting. The usual adjustment for Konis on the Porsche 912 is softest--I suspect that the only people who change the setting are racers. Removing them from the rear is not too hard, but from the front it's much more difficult. The TR should be much easier. Still, I can't see myself using that feature much, if at all. But a well designed, good quality product has its attractions, for sure.
G Right-Side Shock Weeping Oil Austin Healey 1
G Squeaking Armstrong Shock Absorber Austin Healey 7
Celtic 77 General MG Lever shock oil refiller MG 0
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
Boink Ugly Shock Failure Spridgets 3
H Shock absorber conversion Austin Healey 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
C MGA Shock fluid MG 14
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
AUSMHLY Lever Shock Oil Level Austin Healey 41
M e-type siries 1.5 shock abosorbers Jaguar 3
O Shock Absorber maintenance Spridgets 4
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
Raymond General Tech Shock oil MG 4
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
John Turney Left Rear Shock Mount Austin Healey 5
R Shock Absorber Austin Healey 0
Griz Shock failure Austin Healey 4
S TR6 TR6 shock links Triumph 10
G TR4/4A Front Shock Install Triumph 14
G BJ-7 Rear Shock Link Austin Healey 2
wkilleffer MGB Armstrong shock oil- 20W oil? MG 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
T TR2/3/3A How important are matching rear shock links? Triumph 9
maxwedge5281 front shock absorber mounting Austin Healey 3
T Tube shock conversion BJ8 Austin Healey 6
D TR4/4A stubborn lever shock link Triumph 2
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
T Function - Armstrong Lever Arm Shock Spridgets 2
T Filling an Armstrong Lever Arm Shock Spridgets 0
