TR6 TR6 shock links
Sumton
car has heavy duty lever shocks and lots of Goodparts suspension and engine mods and really, really sticky tires on wider wheels.
i broke a shock link and i'm wondering - is it stress due to the tires/suspension setup, is it old age (of the part, not me), is it just a random thing, or what??? p1030909.jpg
TR4nut
I don't see any of the bonded rubber in that link anymore so I'd guess age was probably the main reason.
mrv8q
Hey, Randy, how is the weather out your way? Hope you are making our OK!
Tr6easyrider
Could be, when you replaced them the last time, you tighten the link to the shock with the trailing arm hanging freely, thus putting stress on the rubber in the link. Jack the trailing arm up too its neutral position, then tighten the nut. This will put less stress on the rubber.
Sarastro
That's a good rule for all rubber suspension bits, such as bushings. They work by flexing, so they should be unstressed in the neutral position. The standard technique is to tighten them with full weight on the suspension. This is true of all cars having rubber bushings, not just LBCs.
ed_h
The last couple of sets of links I bought had no bond between the ball and the rubber. The balls were captive, but would turn freely, though pretty stiffly. I'm not sure if this is intentional or a defect, but if this is the case with a new set, it wouldn't matter if the links were tightened with the suspension loaded or not.
Ed
AndreL
...both damper links broke on mine after ~3000 miles (links purchased Aug. 2016).
I surmised the cause was either a nasty bump on the road or manufacturing defect.
The supplier had one other report of failure.
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
S TR6 tr6 rear shock part number ??? Triumph 5
I TR6 TR6 front shock help Triumph 2
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
T TR6 TR6 Rear lever shock rebuild: Triumph 3
C TR6 TR6 Shock Conversion Kits Triumph 13
A TR6 TR6 Rear Tube Shock Conversions Triumph 13
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
M TR6 Help- TR6 rear shock mount cracked Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
