My '79 MGB that has always had the ZS carb doesn't run rich....
I meant to say, the jet - when you remove the air cleaner & lift the carb, & look into the hole, is the jet level with the carb body....&, is it centered in the hole? Does the needle go into the jet without hitting the jet?
