rich enough that she is leaving soot on the snow.
First off, could it be something as simple as the rings not fully seated? I've run the car for maybe an hour total and likely put 2 miles on it.
And/Or, is there something I can do?
To recap, it is a Zenith Stromberg. Water choke has been removed and replaced with a manual choke - which is not currently hooked up and which I have not actually needed to start the engine. As well, I am not running the original air cleaner as it did not come with the car. Instead I have a longflo air cleaner (https://www.victoriabritish.com/ICATALOG/SM/full.aspx?Page=30)Also, all the pollution stuff is disconnected.
thanks all
thanks all
