Running Rich in California
skinsgamer
Member
Does anybody know a trick to get the ZS to run leaner? My mechanic and I have both tried unsuccessfully to lean my 78' midget down enough to pass smog.
I've tried 3 different ZS carbs, one was even a manual choke (illegal for me in Cali), nothing is working.
Is there a known cause, I know ZS tend to run rich naturally which has been the demise of many midgets. Thanks to superior British engineering, locating the Cat directly under the Carbs fuel bowl?
Anyway, it's been 3 years of frustration and I'd like to get her back on the road.
tweety
No one is rich in California anymore!
What city are you in? My mechanic (outside San Diego) got mine to pass with flying colors. Are you sure it's a rich mix? Mine had carb issues, and a hollow cat. New cat and "FrankenCarb" (two z-s cobbled together) and all was well.
JPSmit
I am running an aftermarket aircleaner - longflo. I taped off half the aircleaner and it leaned right out. Oh, and while I am more than happy to be corrected, I think a new coil helped too
Woodie
can't new needles be installed like SU carbs, that run leaner??
skinsgamer
skinsgamer
Member
Tweety, I'm in Ridgcrest, Ca (3.5hrs north of San Diego). You are running twin ZS? I don't think mine will pass visual with that set-up, as far as I've seen for a 78' only the single ZS is authorized and the smog checkers here a fanatical about the visual.
My cat could definitely be bad, it's been cooked a few times (glowing red). But I don't want to put new one on until the rich issue is addressed or I may ruin the new one.
Funny thing is, I have a Mikuni carb tuned for the midget which runs great but doesn't pass visual. SAD
skinsgamer
skinsgamer
Member
JPSMit, I never thought of reducing the airflow into the carb. I'll mention that to my mechanic and see if we can get it leaned out some from there. Then maybe a new Cat.
skinsgamer
skinsgamer
Member
Did you use a universal cat (magna flow 5300 series or similar) or did you find an OEM style front pipe w/ cat?
JPSmit
I don't think you can with ZS's - we recently had this conversation and I think there is a different principle with ZS
JPSmit
not Cat - coil - my plugs were black and wet and I think a stronger spark helped.
tweety
Did you use a universal cat (magna flow 5300 series or similar) or did you find an OEM style front pipe w/ cat? [/quote]
It was an oem style bolt on replacment. Fit perfectly. It was a lot less than moss and VB. I think the guy actually made it to order. I'll see if I can find the info on it.
skinsgamer
skinsgamer
Member
Moss doesn't even list it anymore and the only OEM one I could find listed was $355.00 before shipping. Ouch!
skinsgamer
skinsgamer
Member
The coil on mine is brand new from before this started. But, maybe a different brand higher voltage spark could help. What brand coil did you put on?
tweety
Rockauto.com has a non California unit for $179.00 I think a I paid a little more but they guy would ship it into CA where Rock Auto would not.
I still have not found the info on the one I bought, but it was around $180+ shipping.
skinsgamer
skinsgamer
Member
Hmm,
I could have Rock Auto ship to my In Laws in Washington State. They could send to me from there! In fact I should take the Midget to them and register and title it there!
JPSmit
mine was just the generic - pick it up at PartSource coil - I think the name is Standard - wasn't any kind of high output though
tweety
skinsgamer said:
Hmm,
From what I understand, the Cats are all the same. The CA certified ones cost more etc because they are tested by some lab. That testing costs money so they tack on the fees.
My mechanic could only provide a CA certified cat as his shop was a "Gold Shield" station. They would ultimately be the ones that tested and documented my car. If I brought them a Cat, it did not matter, there's no way for them to tell that is was not a CA cat.
You could always try Rock Auto and see if it slips through their ordering system.
I swear that I got mine through e-bay, but I can't find any history.
skinsgamer
skinsgamer
Member
Tweety, good info on the Cat being the same except for the california testing cost. That's the reason we can only use the ZS on our car too, no company wants to pay the huge cost of getting CA certified for a Midget. There's just not enough on the road to warrant the cost, so we are stuck.
I will either go ebay or have Rock Auto ship it to my in-laws and have them send it down to me.
Right now I need to get the carb to run leaner. My mechanic made a special tool to either adjust the needle or floats ( I can't remember what he said). Hoping it works. Spring is in the air out here in the High Desert 71 degrees today!
bthompson
My money's on your mechanic making a needle adjuster. He can drop it down the dashpot hole and screw the needle down a few turns, so it sits lower in the jet. That'll lean it out a bit, if it isn't screwed all the way down already. Have you checked for air leaks around the manifold, gaskets, and throttle linkage? Is your EGR valve closing all the way? Any little vacuum leaks between the carb and the engine will cause a ZS to run rich. And like JP said, blocking off part of the air cleaner (restricting the airflow is the goal) will help too.
BugEyeBear
SO GLAD that I don't have to deal with those CA Smog Tests anymore!!
(I lived out there when they 1st started doing smog tests, and again when they started doing the visual inspections, & again with the "rolling load" tests... Not fun for the sports car enthusiast!)
Back in the day, my buddies & I all had pumped up Datsun 510s w 2.0 Liter SSS engines that we had imported in from Japan. These spunky little engines had dual SU carbs, high compression, shaved cranks, lightened flywheels, high red-lines, and were a BARGAIN at approx $300-$500 each (before mods). They were slightly used, cut out of a Japan market car, & shipped to the US on a pallet!
We used to keep an old stock US-spec 510 engine around just for installing once every 2 years for the CA smog test. We would bolt in this oil burning lump, drive down to the smog inspection station, get the test done, then drive home & YANK IT OUT! I just KNOW that the smog guy recognized the same engine being tested in half a dozen cars, but he never said anything. (He probably didn't want to lose the revenue flow...)
I'd be willing to bet that our SSS engines actually ran MUCH cleaner than the worn out stock US-spec motor. But the visual inspection REQUIRED that all the US-spec smog equipment be present, so we were forced to do the temporary swap.
Q: Does CA still have a limit on the cost of repairs to pass a smog test? (as long as all the smog equipment is present, that is) Or did they eliminate that "get out of jail free" option??
I do know that 1975 & older vehicles are smog exempt in CA. Yet another reason to buy the earlier marques....
Best of luck getting her to pass!
-Bear- :cheers:
JPSmit
BugEyeBear said:
SO GLAD that I don't have to deal with those CA Smog Tests anymore!!-Bear- :cheers:
Yeah, I'm really glad I don't have to put up with those nasty California - where the weather is warm - smog tests and instead have to put up with freezing Ontario - where they also have smog tests. :cryin: :wall: :cryin: :wall:
S TR2/3/3A Running rich SUs. Triumph 25
F TR2/3/3A SUs Running Rich Triumph 25
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
doc50 TR2/3/3A Running rich Triumph 9
cmacmillan TR6 question about running rich and pollution control Triumph 2
A Spitfire 78 spitfire running rich Triumph 5
M Running rich Triumph 6
J TR2/3/3A TR3A is running too rich Triumph 4
7 Still running to rich Triumph 1
F Running rich Austin Healey 8
JPSmit She's running - but rich Spridgets 18
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
A Spitfire Spitfire Running Rich Triumph 7
Dudly Running Rich Triumph 18
glemon Carbs Running Rich Austin Healey 30
B running rich dgav Spridgets 1
RedTR3 TR2/3/3A TR3 Front Carb Running Rich Triumph 13
startech47 Running rich Spridgets 4
sparkydave Rich running Spridgets 22
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
