Dudly
Hello all-
Ok the 79 Spitfire Is safe in its new spot in the garage. (Daughter named it "Sushi" by the way.
I seem to be having a problem with running rich and a little "chugging". At first I thought it was vapor lock, as it has been well in to the humid 90's here in NE Ohio. But as the evening cools the issue seemed to continue. My carb is stock with the auto choke. I am about to replace the vacuum lines. Is it possible that the auto choke is stuck and or causing the problem. It has electronic ignition and seems to be working ok.
Sushi only has 35K and has not been run very hard in her life. Could that also be the issue?
(Yesterday she seemed to really enjoy a flat out run round the block).
Thanks
Thanks
