Midget that runs too rich
BKRTEE
I rebuiltthe engine & carb on my 76 Midget a couple of years ago and can't get the barb to run any leaner by adjusting the allen screw inside the carb. As I recall, I think the original needle was a bit longer than the new one that replaced it; but at the time being new to all this, I just tossed it in favor of the replacement. The former electronic ignition was replaced by points before I bought the car. Could I have the wrong needle even though the catalog specified the current one? How can I get the correct needle if that's the case? There is no specific tag on the Stronberg carb (150), so I'm not even sure if it was the original one meant for the 76. Any thoughts?
jcatnite
You might be in a bind on the carb deal. If it is the original carb, then you need a 44A. What type of choke is on the car? If the choke circuit is leaking by then there is nothing you will be able to do with the needle to keep it from running rich until you fix that. Other then the carb, the engine will run extremely rich if your spark is weak to the cylinders. It could be time to check the plugs, points, cap, and condensor to make sure that they are all performing up to par. I have never been able to totally tune the richness out of my 76 but I have been able to get it to where the plugs are nice and tan unless I let it idle extensively then it starts to richen up. I would take it a step at a time and rule out the ignition first.
JC
B
BKRTEE
Thanks for the observations. I've pretty much exhausted all those options except trying another needle. I decided earlier today to go ahead and order a 45Q that's supposed to go on the 78-79 models. It seems the only other logical option since the other two needles are for California cars. I did notice this evening when I pushed the choke all the way in, it was not quite driving the carb armature completely home (off about 1/8"). I readjusted the cable at the locknut to correct. It's raining this evening in the wonderful Northern Ohio area, so no way I was going out. We'll see if there's any improvement manana.
The car has and still is running pretty well. If I can lick this, that's the last problem...until the next one!
But that's the charm of an MG!
jcatnite
Oh my mistake. I thought that all the ZS150's after 76 used the 44A. Let us know how the new needle treats you!
JC
B
BKRTEE
Installed the new 45Q needle in place of the 44A this evening. I leaned it out about one turn. With no exhaust analyzer, I'm at a bit of a disadvantage to tell the difference in mixture. The car seemed peppier as I took it out. One good sign: the idle came down to where I can adjust it. I was unable to get it under 1200 rpm before with the screw all the way up. Now it's in the range of 750-900 where it should be. Guess I'll run it for awhile on the highway then take a look at the plugs.
jcatnite
That is the best way that I've discovered to check the mixture ratio. The only thing is, it doesn't tell you that much about how it is idling. I have a colortune 500 that I have tried with varied success. Theoretically, if the ratio is proper at highway speed, it should be close when idling but I think any mismatch is magnified down at idle.
JC
Simon TR4a
I think you will need new plugs to get any meaningful information, you can't read plugs that have been in use.
So get a set of 4, change one at a time, after each change you can compare.
Since you changed other settings (choke) you might want to go back to the original needle at the end for a cross check.
Also, an old, dirty air filter could contribute to the problem, though I guess you thought of that.
Simon.
M Midget runs inconsistently Spridgets 7
C '72 Midget Runs On 2 Cylinders at Highway Speeds Spridgets 73
zimmy my 74 mg midget video! it finally runs! MG 4
M midget runs better when cold MG 9
F 77 Midget- ENGINE RUNS BUT WHEELS DON'T MOVE -help MG 5
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
