Luke_Healey
On the 'new' Sprite, I have the carbs set according to the manual when idling, but the car is running very rich and not putting out a whole lot of power. The plugs are sooted up with carbon.
I sound synced the carbs at idle and used the starting point on the jet nuts. The adjustment on the jet nuts was started at 12 faces turned down. However, to achieve fastest idle and pass the rise and fall RPM test, I had to turn them out further quite a bit (richer than the starting point.)
Is there a secret to getting them to the point they are making the best mixture as well as the best idle?
I'm sure this is asked all the time and varies car by car, but I figured I'd fire it off anyway.
My other Sprite is running seemingly properly according to the plugs and definitely has more get up and go. It also gets over 35mpg fuel mileage even with me whooping its butt.
