How to Adjust Voltage Regulator
68Sprite
I have converted from Gen. to Alt. and the car is only showing 12.5 to 12.7 volts when running. The regulator is new. How do I adjust it. Or any links to info on the subject. Thanks
G HD8 Idle Adjust Screw Austin Healey 10
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
V 89 XJ6, How to adjust front camber? Jaguar 2
T TR4/4A adjust fuel level Triumph 8
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
gbtr6 TR6 Valve Adjust, What clearance? Triumph 5
bighealeysource Best way to adjust doors Austin Healey 9
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
J TR2/3/3A steering stops , how to adjust Triumph 2
S Clutch self-adjust? Austin Healey 28
S Adjust mixture on a BT7 Austin Healey 9
T SPQR Tappet adjuster, Click Adjust Austin Healey 1
H Stromberg Carb Sync and adjust Triumph 6
B Adjust headlights/ "true" them? MG 7
M How often to check/adjust valves? Triumph 7
B Triple carb setup too rich? How to adjust? Austin Healey 3
memphis Torque Head Bolts & Adjust Valves Austin Healey 13
W handbrake adjust Austin Healey 2
T looking for valve adjust shortcut. Triumph 33
QuickSilver I Need An Alternator Adjust Bolt MG 0
K SU Mix Adjust Memory Refresh Triumph 7
K TR2/3/3A TR3: carb adjust mixture ie. how many flats... Triumph 12
T Bonnet Latch Adjustment [how to adjust bonnet latch [BJ7] to keep it closed] Austin Healey 14
F Hydraulic clutch adjust Triumph 9
Pythias Click Adjust? Spridgets 6
MTribe how to adjust static timing? Triumph 8
bluemiata90 Wedge TR8 adjust cold start idle and warm temp idle Triumph 3
Luke_Healey How to adjust rich SUs Spridgets 7
C TR6 Proper way to adjust front hubs, TR6? Triumph 13
jlaird How to test and adjust a fuel gauge Spridgets 25
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
W handbrake adjust Austin Healey 1
H How to Adjust Valves in 100-6? Austin Healey 10
KLUTZ Will this door corner somehow adjust in? MG 11
L KYB Gas-adjust shocks Triumph 1
Ed_K What is the best way to align/adjust the doors ? Austin Healey 8
T TR6 Special tool needed to adjust TR6 rear brakes? Triumph 9
Slider748 TR6 How to adjust idle mixture on TR6 Triumph 10
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
