roadsteroldster
Member
'72 TR6, built Sept '71.
The car quit at the end of the driveway. No voltage for anything. Battery is new, 12.67v, 12.5v at the starter cable connection. However there is no voltage at the ignition switch tap on the starter solenoid (white/red wire). Is there an internal fuse between the battery connection on the solenoid and the ignition tap? Also there is an unused tap on the solenoid that does have power. Can I use that for ignition power? I was going to a car show on Sunday. . . .
Let me know, thanks
Let me know, thanks
