Voltage Output Question
60Bugeyefan
Car has been sitting for a couple of weeks. Today while driving I noticed that the voltage meter was registering 15-16 volts generator output which seems high. Does the voltage regulator needs adjusting or is this normal?
Sarastro
That's way too high. What kind of meter are you using? I ask because digital meters can give an erroneous reading in auto electrical systems (because there's a lot of electrical noise, which the digital meter doesn't like). Use an analog meter, which is what most of the automotive meters are.
You might be able to adjust the regulator (see the shop manual--it's easy) or it might be fried.
Deleted member 8987
Or simply check the ground to the regulator from the generator. The way regulators work is they have to sense a proper voltage....usually a very high charge voltage is due to a failed or corroded grounding wire.
Using a voltmeter to check for voltage potential between ground lug on regulator and case of generator while running will tell you. Should be zero point zero zero zero and maybe a tad after that.
N DC voltage output f Austin Healey 2
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
T TR4/4A Why is the new voltage stabilizer I got marked with 'top"? Triumph 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
Jim_Gruber Voltage Regulator Question Spridgets 4
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
M TR4/4A Voltage Stabilizer question. Triumph 10
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
M TR4/4A Voltage Stabilizer TR4A. Triumph 14
Superwrench Voltage Reg Austin Healey 1
J TR4/4A TR4A voltage regulator help Triumph 16
G low voltage to right side turn signal Austin Healey 3
Bob Claffie Voltage stabilizer Triumph 10
A Headlight Voltage Drop MG 5
G Only voltage gauge works Triumph 10
Twosheds Voltage Regulator Lecture Triumph 11
M TR2/3/3A tr-3a Voltage Regulator Triumph 25
M voltage regulator adjustment hard Spridgets 18
