TR4/4A Voltage Stabilizer TR4A.
mtlman8
I went over the electrical system the other day, and Decided to Bypass the voltage stabilizer with an inline fuse (10 amp) is there any harm in this?
Billm
Your fuel gauge will not be quite as consistent (due to changing voltages) but no other changes should happen (assuming that the car is wired correctly stock).
You should not need the fuse since the power should only go to your fuel gauge.
BillM
M
mtlman8
Thanks bill.I had a fuel gauge issue to start with but was resolved after I bypassed the stabilizer.
Billm
They make "solid-state" voltage regulators but I just don't bother with them at all.
Bill
Billm
I will definitely believe that- I have a mechanical temp gauge so don't think about that.
Bill
M
mtlman8
All gauges seen to work just fine, I don't know what the stabilizer was for, but since I've gone to an alternator everything works as it should.I put the inline fuse in as a "just in case" sort of thing because I was not sure.
HerronScott
Aaron's right. Both the fuel gauge and temperature gauge will be affected.
The regulator supplies 10V so both gauges should read high running from battery/generator 12+ volts.
Scott
M
mtlman8
So without the stabilizer, It will run at 12 volts as apposed to 10 volts appearing higher at both gauges?
M
mtlman8
I just ordered a new one from Moss... Thanks guys.
TR3driver
Great Pumpkin - R.I.P
It wouldn't be difficult to recalibrate the gauges to work on 12v; the problem is that the battery voltage is nowhere near constant. Idling at a stoplight with the headlights and heater on, it can easily droop to 12.0. Running down the road on a cold day, it should be closer to 14.0 volts. The gauges respond to the square of the voltage, so it makes a noticeable difference on the reading. That's why the original setup used the "stabilizer".
I did something similar to what is shown at https://www.britishv8.org/Articles/MGB-Voltage-Stabilizer.htm; except my NTE1953 didn't seem to regulate properly without some capacitance on the input and output.
dklawson
I also put together a PDF on troubleshooting and replacing the stabilizer.
https://home.mindspring.com/~purlawson/files/SmithsVoltageStabilizer.pdf
Like Randall said, with the charging system working the gauges will really see closer to 14V. Since the stabilizer is supposed to supply 10V, that means your gauges will be operating on as much as 40% too much voltage. That means higher current flow, higher gauge readings, and... more heat.
So bypassing the stabilizer will cause the gauge readings to be high and it can potentially shorten the life of both the gauge and sending unit.
The easiest method of replacement is to buy Moss's solid state stabilizer. I think they are now under $15 each. The DIY method shown in my PDF and in Randall's link is another possibility. However... the absolute cheapest solution is to solder wires directly to the 7810 regulator chip, cover all the leads with heat shrink tubing. Then terminate the wires with crimp terminals and use the mounting hole on the chip to attach it to a metal surface behind the dashboard. On the Spitfire I ran one chip per gauge instead of one chip for two gauges. The chips are cheap from sources like Mouser.com and if you can solder this gives you an inexpensive and long life repair.
The picture link below is for the simplest implementation of a 7810 chip as a voltage stabilizer.
https://www.adocars.com/elf-ado/elf/elfimages/v-reg.jpg
Adrio
and if you have positive ground on your car use the 7910 rather than the 7810.
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
T TR4/4A Why is the new voltage stabilizer I got marked with 'top"? Triumph 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
M TR4/4A Voltage Stabilizer question. Triumph 10
Bob Claffie Voltage stabilizer Triumph 10
B Gas Guage Not Working--Voltage Stabilizer? Spridgets 17
RJS Voltage Stabilizer [Mal]Function Triumph 3
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
Brosky Leaky voltage stabilizer Triumph 7
Raymond voltage stabilizer MG 15
L Voltage Stabilizer MG 20
middleagecrazy Voltage stabilizer Triumph 10
Got_All_4 Voltage stabilizer alternator upgrade problem Triumph 2
M Normal Temp and Voltage Stabilizer MG 9
Trevor Jessie Voltage stabilizer Spridgets 4
Mickey Richaud Voltage Stabilizer Question MG 14
Bruce Bowker voltage stabilizer British Motor Corp 6
Cain Fuel Gauge/Voltage Stabilizer Triumph 1
M voltage stabilizer Triumph 3
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
Jim_Gruber Voltage Regulator Question Spridgets 4
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
