well I got my Dan masters book out, and as stated in previous post, make sure you have power to the stabilizer, green wire so check fuses first, next check the stabilizer with a meter you will get a reading from 0 then 12 and 0 and 12 as the stabilizer is working, check wires at the gauges, you can pull the wires off the senders, fuel and temp, touch them to ground and the gauge should go to full scale, if not you have wiring issues or gauge problems
lets us know, I should be working but just dont feel like calling anyone today
Hondo
