Rear hub reassembly [Rotoflex]
roger_abbott
I am rebuilding the right rear hub on my 72 GT6 - new bearings and seals. My problem involves reassembling the hub to the drive shaft. Apparently, the PO ran into the same problem because was not driven onto the drive shaft fully, allowing too much play in the bearings, which is the problem I set out to fix.
The hub has internal splines and fits onto the splines on the drive shaft. It is a very tight fit. I was not able to get the hub fully onto the shaft using the hub nut and a 24" breaker bar. I stopped when I became concerned that I would strip the threads on the axle shaft. The instructions in the Bentley manual are to use a "slave" nut, which means, I guess, that you probably ruin it in the process.
Has anyone encountered this particular problem and if so, how did you handle it?
R
roger_abbott
I guess Triumph rear hub bearings never fail - no one offered any advice on my problem. So I embarked on my own solution. Should anyone try to rebuild a rear humb, perhaps they can benefit from my experience with this one.
First, my comments apply only to Rotoflex-equipped cars. The problem, as it turned out, was that the two halves of the hub could not be made to come together by tightening the axle nut. The solution was to remove the inner axle shaft by unbolting it from the Rotoflex coupling. This allows the hub assembly to be placed in a press. It took 5 tons of pressure to bring the two halves of the hub together. It is necessary to do this so that the inside and outside bearngs are the rignt distance from each other. The hub must have end play of .0005" to .0025", i.e., just slightly loose. This distance is set by one or more shims that fit between the two halves of the hub. The illustrations and explanations in the Bentley manual (pages 3-125 through 3-127) are clear, but the method of final assembly suggested isn't workable.
By using a press, you avoid risking damage to the axle shaft threads.
I did not have any shims other than the one that came with the axle. Fortunately, my guess that the manufacdturing tolerances on the new bearings would be very close to the original bearings was right and I did not have to fiddle with machining shims.
Getting the assembled axle and upright back on the car is a perfect PIA. The repair made a huge difference in the handling of the car. I sure hope I never have to do it again.
trrdster2000
Rogers, Nice job, sorry I haven't been on the board lately or I could have told you about the press and sent you a picture of the bar, with specs, that is used to put the spring back on. If you end up doing the other side, I will get it to you. I would send the bar but it weights a good bit. Wayne
svtmikey
Roger,
I just did mine and had a heck of a time figuring out exactly what you did.....a press is what I used.
I have been on the road for a month and haven't been logged in for a while or I would have gladly told you that as well!
Too bad, I have been waiting to contribute something I have learned on my ongoing GT6 rebuild for a long time, and just missed the chance!!
I do better next time.
W Rear Hub Reassembly Austin Healey 7
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Rob Glasgow Rear Hub Nuts Austin Healey 11
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
J TR2/3/3A Hole in Rear Hub Triumph 7
K Rear Hub Re-assembly Austin Healey 4
KVH General TR Rear Hub Backing Plate Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
K TR2/3/3A Rear axle hub removal? Triumph 8
G Loose lugs on rear hub Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
T TR2/3/3A Rear Hub Stud Removal Triumph 4
AngliaGT TR6 Need a Rear Hub Triumph 1
C Rear Hub Removal - How Do I? Austin Healey 8
D Rear hub confusion Austin Healey 5
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
B Spitfire advice on rear axle/hub Triumph 4
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
B Rear Hub Extension Studs Austin Healey 22
J Rear Hub/Bearing Question Spridgets 4
PHerder Rear Hub Removal??? Spridgets 10
Dougal BN1 rear hub markings Austin Healey 3
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
Barryp Rear hub seal speedy sleeves? Austin Healey 2
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
T REAR HUB REMOVAL Spridgets 4
JPSmit Rear Hub Question Spridgets 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
MadRiver Rear Hub Puller? Austin Healey 4
glemon Bent Rear Hub/Axle Triumph 2
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
D Left rear hub nut Austin Healey 9
D Rear Hub install Austin Healey 2
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
boxfullofyertoys Rear hub nut size Spridgets 10
B Right hand side rear hub nut Austin Healey 3
dklawson Spitfire Spitfire MkIV - Rear Hub Questions Triumph 4
M MGB MGB Banjo Rear Hub re and re wire wheels MG 0
