Pinion Seal Replacement
NAGA
Hey Guys,
1966 MKIII Sprite.
I have the rear end carrier out of the housing, intending to change the gasket while I'm redoing the wheel cylinders, axle seals etc.
My question is about changing the pinion seal. Now that I get a good look at the carrier, the pinion seal might be leaking too although the gasket was rock hard and came out in oil-soaked pieces. I've never done that job before. Anything tricky? Certainly just changing the seal won't affect gear lash or anything.
I'd hate to be here and a month from how wish I had changed the pinion seal while there.
I'm new to this forum. How do I search for previous threads on this subject?
TIA,
Donald
nomad
Yes, that job requires more than just undoing a nut and popping in a new seal. Try "advance search" top right on the page. Need anything more and the group will oblige!:smile-new:
drooartz
Welcome!
As nomad says, try the search up in the top right corner and see what comes up. Don't be afraid to ask questions even if they may have been asked before. We won't bite. :grin:
I did the pinion seal in my Morris Minor (same carrier as a Sprite) last year. It's not a hard job, but I did have to make one tool. Took some angle iron and modified it so that it would bolt to two of the holes on the pinion (where the drive shaft bolts to). Angle iron was a couple feet long. This held things in place so I could loosen the nut -- without this "tool" in place it just spun. I wound up reinstalling the carrier, bolting on my brace, and loosening the bolt while it was all on the car. Once loose it was easy enough to get it all apart and put in a new seal.
Others will likely chime in with tips and things to watch out for.
D BT-7 pinion seal replacement Austin Healey 8
mcmillal TR4/4A Pinion Oil Seal Replacement Triumph 10
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
S Pinion seal replacement Triumph 4
svtmikey Pinion Seal Replacement Triumph 1
F MGB Pinion Oil Seal Replacement - MGB Tube Type Axel MG 8
T Pinion seal replacement Spridgets 7
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
edkap2002 TR6 TR6 rear pinion seal Triumph 3
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
luke44 TR2/3/3A TR3 pinion seal - leaked from sitting will it reseal? Triumph 12
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
Sarastro TR4/4A New pinion seal doesn't fit! Triumph 20
T Steering Box Pinion Seal [?] Spridgets 1
KVH General TR Pinion Seal Goof Up Triumph 3
Boink 3.9 diff and pinion seal Spridgets 2
drooartz Diff pinion seal Spridgets 8
Geo Hahn General TR Diff Pinion Seal Triumph 5
H Pinion seal PN Austin Healey 2
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
HealeyRick Pinion Seal Questions Austin Healey 8
Willie_P Hibernation over...I'm back...Pinion Seal question Triumph 4
O TR6 TR6 Pinion Seal Triumph 4
Bremer TR2/3/3A TR3A pinion seal removal Triumph 8
bighealeysource Pinion shaft oil seal -Latest to oil leak Austin Healey 8
jvandyke pinion oil seal failure? Spridgets 2
71tr Part No. for Nissan R200 diff pinion seal Triumph 0
R MGB MGB pinion seal MG 2
CCURTISS Rear Axle Pinion Seal Triumph 7
rlandrum Bad Pinion Seal Triumph 4
prb51 TR2/3/3A TR3 Dif Pinion seal and speedy sleeve Triumph 12
MtnDriver Replacing Pinion Oil Seal MG 6
D TR4/4A TR4 rear diff pinion seal Triumph 4
Westfield_XI Steering pinion oil seal Spridgets 11
G TR5/TR250 TR 250/early 6 rear pinion oil seal Triumph 0
prb51 TR2/3/3A 56 TR3 pinion seal Triumph 8
S Changing the Rear End Pinion Seal Triumph 3
Musicman R & R of Pinion Oil Seal Triumph 8
Musicman Possible Seeping Pinion Oil Seal Triumph 6
S TR2/3/3A Pinion tail bearing replacing Triumph 12
M MGA RHD twin cam steering pinion MG 0
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
T 3.54 Crown & Pinion Sources Austin Healey 13
M MGA RHD rack and pinion wanted MG 19
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
