General TR Diff Pinion Seal
Geo Hahn
A friend needs help replacing the pinion seal on his TR6 diff. I have done this on a TR3 and a TR4 -- is it the same task on an IRS diff? Thanks!
Note - since an IRS has several seals, perhaps I should specify I am referring to the one for the input flange.
TR3driver
Great Pumpkin - R.I.P
Early or late TR6? Early ones are the same; later units have a crush sleeve to set the spacing inside the diff. Supposedly the sleeve must be replaced every time the nut is removed; but you may be able to get away with just marking the original position and putting it back there after changing the seal.
Moss catalog shows the crush sleeve was introduced at CC61571, which I guess is sometime in 1970. Of course, someone may have swapped diffs around ...
titanic
I think you will have to remove the diff from the car (on IRS models) to change the pinion seal as access is very limited and the front mounting plate will have to be removed. Also, the seals on the axles should be changed at the same time. Removing the axle flanges to change the seals can be challenging without the proper fixture to support the flange. Phil will probably offer his services of separating the flange for just the cost of shipping.
I think the change from the solid spacer to the collapsible one occurred later the comm. number listed in the catalogs. Solid spacers are usually used with a castellated nut and solid spacers with a nylock nut. At least, that is the way they left the factory.
Berry
Geo Hahn
Geo Hahn
It's a '73 though I do not have the commission number handy. I'll 'advise him of his rights' and get more info.
Time is an issue (a Brit who is only in Tucson until spring) as is expense (as it always is).
Thanks for the responses.
TR3driver
Come to think of it, maybe Berry is right. I don't wrench on TR6 very often, but helped a buddy with his some years ago. We did drop the diff, I just don't recall for certain if that was only to change that seal or whether he was also concerned over the condition of the diff mounts to the frame (a known weak spot). IIRC we did find some cracks that could not be seen before lowering it, and he trailered the car off to have reinforcements welded in.
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Boink 3.9 diff and pinion seal Spridgets 2
drooartz Diff pinion seal Spridgets 8
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
71tr Part No. for Nissan R200 diff pinion seal Triumph 0
D TR4/4A TR4 rear diff pinion seal Triumph 4
drooartz Diff pinion nut Spridgets 10
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
Rut Diff plug tool Spridgets 7
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
Willie_P Quick question: rear diff TR 3/4 Triumph 6
K TR2/3/3A Randall.....4:35 Diff in a TR3? Triumph 4
