Wedge Diff Cover Gasket Adhesive
JFS
Bronze
After having my rear differential rebuilt a couple years ago, the rear cover now leaks. The sealant used by the shop appears to be a red RTV. What sealant should I use with my new rear cover gasket? Any suggestions?
Darrell_Walker
In theory it shouldn't need anything. What often happens is the bolts are torqued too much and distort the cover, make sure the flange is flat.
That said, I like to glue gaskets to the removable part (cover) with RTV, and use a non-setting sealer (hylomar or the like) on the other surface.
TR3driver
Great Pumpkin - R.I.P
What he said, except I use Hylomar on both sides. The important bit is getting the sealing surfaces perfectly flat.
JFS
JFS
Bronze
Thanks Darrell and Randall. I'll work the cover flat and look for some Hylomar.
TR4nut
I tried to use hylomar but apparently I had some distortion on the cover - couldn't get a seal. I went with a permatex gasket sealant (non-rtv type) and it's been leak free. I wasn't worried about destroying the gasket as I rarely open up the case and it's easy to clean up the surfaces.
tr8todd
There is a trick to installing diff gaskets and oil pan gaskets on the wedges. Coat both sides of the gasket lightly with your choice of sealant, and let it sit for a few minutes so that it starts to dry. I like black RTV because it doesn't look stupid when it squeezes out like the red stuff does. Install the gasket, cover and bolts, but only tighten them a little bit. Go back the next day after the sealant has had a chance to set and torque the bolts down. If you try to torque it down with the sealant wet, the gasket will stretch and squeeze out the sides.
DNK
Did that with my oil pan when I installed it with the "Right Stuff"
Well see how it comes off when the garage climate is a little more reasonable
justin_mercier
Permatex Gear Oil RTV Gasket Maker
"Specially formulated for differentials and transfer cases to resist modern gear oil friction modifiers that can break down normal RTV and cause leaks.
Justin- What's the company name
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
Willie_P Quick question: rear diff TR 3/4 Triumph 6
K TR2/3/3A Randall.....4:35 Diff in a TR3? Triumph 4
TRclassic3 TR2/3/3A diff free play tr3 Triumph 7
J Which Limited Slip Diff Spridgets 2
