MGC Diff Oil
69MGC
What is the best Weight Oil and brand to put in the Differential of a 69 C?
69MGC
69MGC
No need to reply now guys. I'm going with 75-90 weight Valvoline Synthetic.
G Diff and trans oil Spridgets 8
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
D best oil to use in the diff? Triumph 7
T Series 2 E-Type Diff Oil Leak... Jaguar 5
K Spitfire Tranny and Diff Oil 64 Spit Triumph 9
Dudly Rear Diff Oil Triumph 11
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
VelodromeRacer Rear Diff oil suggestions? Racing 7
Woodie diff oil and noise Spridgets 19
D what diff oil? Jaguar 1
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
A Spitfire How to change diff oil on 78 Spit? Triumph 1
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
