TR4/4A Low mileage TR4
martx-5
They say it was built in '63. My first TR was a '63 I bought in '65, and it had the white dash. When did they go to the wood??
bgbassplyr
Bonnet bulge looks like the long one. Is this correct? Hard to tell w/o a number.
Nice looking though. But not for that price.
Just MHO.
KVH
That is very sharp, well maintained. Definitely one of the nicest around. Not sure the radiator and carbs are original to that year, but perhaps so. Lots of pride of ownership, and not much to cause worry. The price is high, but I could see it go high.
Can anyone comment on that surrey top/backlight panel? Is that aftermarket or original?
HerronScott
The radiator should be correct if the commission number is CT9553 or higher and the carbs are correct (H6's) as long as the engine is earlier than CT21471E (or outside of CT16801E to CT16900E according to the SPC) where they used Strombergs. Short bubble hoods were only the early TR4's as well but I'm not sure where that changed at - the SPC lists a bonnet change at CT6429 so that could be when it happened.
The car has the correct interior pieces for a Surrey top hardtop which were different on a TR4 compared to a softtop car so I would guess this is an original but it is interesting that it's painted white on the inside.
Scott
Andrew Mace
I admit I don't know enough to know whether the rear window surrounds were painted or "trimmed" on these. And the one photo doesn't really help (me) that much:
OTOH, I'm intrigued to see a VTR decal on the window! :banana:
TR4nut
This car reminds me of one that sold in Houston a year or two ago - I tried to dig up some save pictures to see if it was the same but I failed.
The backlight looks original to me, including the trim. That is white vynide you see, not paint. The splice on the trim above the wheel arch is correct.
HerronScott
Ah you are right, that is trim. Duh....
I'll have to check mine to see if they have the trim present and if so what color it is (one's red and the other is green). They've been on the shelf since I bought them so it's been years since I looked at them.
Scott
HerronScott
Randy,
I checked mine out and the nice one has had all of the interior vinyl removed and is just painted nicely inside. The ugly one still has a few strips of white vinyl left around the edges and it has the same pattern as the original visors in the TR4A.
Scott
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
aeronca65t Post-War Other super low mileage Herald Triumph 2
WedgeWorks Wedge Low Mileage 1981 TR7 Triumph 10
M_Pied_Lourd Spitfire Low Mileage Spit Triumph 3
S for a nice low mileage Other Cars 1
angelfj1 TR6 Very Low Mileage TR6 on Ebay Triumph 6
bobh Low Mileage Originals are Hot Triumph 2
G I know its low mileage - but... Triumph 14
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
R Low Brake Pedal Austin Healey 9
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
CJD TR2/3/3A Low Port Head Cracks Triumph 36
R low/high temp engine running question Spridgets 23
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
