    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Low idle oil pressure
BOBBYR
Hi Gang,
Hope you're all doing well. My 65 is running pretty good these days but after a good long ride the oil pressure is at about 10 psi.It has been recommended to me to replace the three inner main bearings and all the rod bearings.This project doesn't really bother me on account I was going to pull the motor ,this winter,anyway. My question is, has anyone done this and how did it work out? I was told this would bring the pressure back and lengthen the engine life around 50,000 miles.Any advice is appreciated
Bobby R
Ed_K
Hi Bobby,
Replacing the bearings will only help your idle oil pressure if they are worn out. How does the person that recommended this to
you know that they are worn out ?
Is your engine making any strange knocking noises ?
What is your oil pressure while driving say at 60 MPH ?
What kind and weight of motor oil are you using ?
Have you removed the oil bypass plunger and spring and checked the plunger head for a smooth , mating surface and the spring for proper length per the shop manual ?
A worn rocker shaft assembly is the more common mechanical source of low oil pressure than bearings.
My 65 had a little lower oil pressure than I liked until after I cleaned up the bypass plunger and stretched the spring back to the proper length. I also switched to Castrol Syntec 20w-50 after I learned that they put additives in the oil for our old solid lifters ( tappets ). That oil seemed to raise the oil pressure at least 5 lbs both at idle and while running down the road.
Ed
GregW
+1 on that. If it hasn't been checked, I'd do that first. If you do it yourself, it costs nothing, 'cept maybe a valve cover gasket.
BOBBYR
BOBBYR
Hi Ed,
I have shimmed the spring which did boost the idle oil pressure by about 5 psi. Also ,the engine is not knocking. The oil pressure at 60 mph is at 65 psi. I know you are right that I should do some troubleshooting before jumping off this cliff. Tomorrow ,I will bring home another oil pressure gauge from work that I know reads correctly and start the process.In work, I rebuild alot of cummins deisels and the common problem with those engines are worn rod bearings.Oh well, like I said ,I guess I should start at the beginning. I don't know if a worn rocker shaft could cause this.I wish I knew more about that and knew a good test to check that.Get back to me if you can. Thanks for your help.
Bobby R
Dave Richards
65 PSI at driving! What's to worry about there, I'd say nothing. I get about 20 PSI at idle and 40-50 at highway speeds. I have 57,000 miles on the original engine, with no strange noises to date.
MarkA
Bobby,
The very next thing I would check would be the rockers shaft assembly. It sounds like they are worn and flowing too much oil which is hurting your low-rpm oil pressure. With the engine warmed up and at idle (and valve cover off), the rocker shaft and arms should only be dripping oil and not squirting or gushing. If you have very much oil flow on top of the head, it's time to have the rocker shaft rebuilt.
We have all gone (or will go through) what you are experiencing. My engine only had 64,000 miles on it when I had the rockers rebuilt. It made a big difference. I now get 30 psi at idle and warm. I used Rocker Arm Specialist: https://www.rockerarms.com
Mark
BOBBYR
BOBBYR
Hi Mark,
Thanks for the e mail address.I talked with a friend of mine at Cummins Diesel and he has a pressurized oil reservoir that they use for leak down tests.With this tester, I can check all the oil clearances. I really hope it turns out to be the rocker shaft. Anyway , thanks again.
Bobby R
Ed_K
Like Dave said, 65 is a little high.
I now get 60 when the engine is cold and 53-55 at highway speed
after it is warmed up.
I get 20 at a fast idle but only 10 or so if it is idling very slowly like mine does after sitting at a stoplight for a while.
10 is a little on the low side at a fast idle. Probably the rocker shaft assembly worn/leaking a little.
What brand and weight motor oil are you using ?
Ed
BOBBYR
BOBBYR
Hi Ed,
Going through the papers that came with the car,my dad always used 30w quaker state.When I got the car, I changed it and put in a straight weight again.I ordered parts from Moss yesterday ,and I'm Switching over to vr1 20-50w.That should help too. I'm sure it can't hurt. Anyway,it's running pretty good these days and I'd like to keep it that way.I'm going to check out this rocker shaft as soon as the gasket comes in and I'll let you know what I find. Thanks for your help.
Bobby R
Stretch
If you are going for an engine rebuild I recommend an oil pump from D Welsh. I think the commonly available new oil pump is weaker. When my engine was rebuilt the builder replaced my relatively new Welsh pump thinking it was old. Lost 5 psi in the deal.
WALTER
Correct me if I'm wrong but, doesn't the oil bypass plunger only prevent the oil pleasure from getting too high?
Walter
Ed_K
Hi Walter,
It works as the controlling mechanism for the oil pressure. That includes both limiting the pressure but it also " builds " the pressure.
If the oil pump is working right and you are not leaking too much oil around worn rocker arms;
.. If the plunger spring is weak ( shorter in length because the spring steel has lost it's shape), the oil pressure in the engine will be low.
.. If you add a spacer under the spring that is too thick, the oil pressure will be too high.
The spring and plunger both " limit " and " build " the oil pressure in the engine if everything else is working as it should.
... Did I get it right Dave ?
// Added the following edit to this post //
I just read Basil's post about Dave ! I had no idea !
I am real sorry to hear this news.
Dave, You are in my prayers !
Sincerely, Ed
BOBBYR low oil pressure is common at idle Austin Healey 17
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
jvandyke sudden low idle Spridgets 5
A rough running after long idle or long low rpm driv Triumph 1
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
johnrip Wedge tr7 engine idle low RPM bounce Triumph 3
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
R Low Brake Pedal Austin Healey 9
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
CJD TR2/3/3A Low Port Head Cracks Triumph 36
aeronca65t Post-War Other super low mileage Herald Triumph 2
R low/high temp engine running question Spridgets 23
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
