Just when you think it's fixed....
sparkydave
Yes, I LOVE my LBC. I LOVE my LBC. Repeat as necessary. /ubbthreads/images/graemlins/crazyeyes.gif Just when you think you've got everything squared away after recently replacing brakes and flushing the cooling system, what's the one commonly replaced part of the cooling system I haven't replaced yet?
Survey says... The water pump. /ubbthreads/images/graemlins/rolleyes.gif
I had wondered about that before after seeing some moisture on the lower nut once or twice this year, but it has certainly decided to let go. Nice antifreeze puddle in the catch pan, so after cleaning things up, tightening hose clamps, and stuffing a paper towel under the weep (flood?) hole, it's getting mighty wet. Thank goodness Vicky Brit has replacements, even if Moss doesn't.
So, anything I should know about water pumps? I've had it out before when I put a new fan clutch in, so I know how to swap the fan clutch. I had heard of spinning the pump while dry to help seat the shaft seals on a new pump, is there any truth to that? Or is there hope of reviving the old one that way? Either way, the new one is going in. I'm not going through the pain of working on the ratzen fratzen cooling system again without putting the new pump in, but if there's hope for the old one as a spare, I'll keep it.
Here's what Moss has to say about it.
A good idea, and I doubt if there's a down-side....
I think this was also discussed on a BCF forum somewhere, sometime...
sparkydave
sparkydave
Ah, I thought I had read it somewhere, and maybe it was the Moss site I read it on. Thanks for the link!
jlaird
Isn't that an intresting tidbit.
jcatnite
I started to mention waterpump the other day when you were experiencing moisture on the front of the engine. I experienced similar symptoms but didn't discover it till I pulled the engine and noticed the water pump shaft had about a 1/4" play in it. I always thought that the liquid that I kept seeing was coming from somewhere near the radiator neck and never suspected the water pump. Glad you found it bud. Thinks for the interesting tidbit on breaking them in. I never would have though of that.
JC
sparkydave
sparkydave
I was starting to wonder about the pump too, but I think it must have stopped leaking briefly. This time it let a more noticeable amount of coolant out and left the bottom stud of the pump wet. Ah well. New one's coming soon.
Platinum
Dave, there used to be a parts house in the Mentor area (or Madison, mebbe) that had LBC parts on the shelf... LOTS of them. Can't remember their name, but it was a "hole in the wall" kinda place, great inventory. I needed some generator brushes once on a trip to Geneva-on-the-Lake, they had 'em on the shelf. Found them in the 'phone book.
George Zeck
Dave --
Had similar probs. If you need some help with local places / parts availability -- email @ spritey at comcast dot net
Mine has been up in the air for 2 wks due to a stupid accel cable (just can't get it set right and idles like I stole it).
George Zeck
Avon Lake, OH
.... waiting to get on the road again.
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
Flash_Harry MGB Fixed a miss! MG 7
F How is the fron valance on BT7 fixed to the car? Austin Healey 1
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
F How is the leading edge of the rear quater trim panel fixed on a AH BT7? Austin Healey 16
Gray_Cat Lotus Elan Fixed Head Coupe FS Malibu CA Lotus 3
Got_All_4 TR2/3/3A Door handle can this bee fixed Triumph 1
Healey Nut Can this be fixed ?? Austin Healey 24
P Fixed gas smell Triumph 0
nevets sputtering issue fixed...it was the timing Austin Healey 4
hondo402000 TR6 TR6 More issues fixed Triumph 3
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
drooartz I fixed something! MG 17
M Weeping fuel pump fixed Triumph 0
richberman Adjustable shock mounts or fixed? Austin Healey 16
Pythias Speedo ...... pffft..... fixed. Spridgets 3
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
martx-5 TR2/3/3A Fixed the tach on my TR3...Sort of Triumph 10
sparkydave Now what? [fixed!] Spridgets 12
H HS6 Fixed needle centering tips Triumph 1
T 1989 xj6 FIXED! Jaguar 2
mountainman TR2/3/3A TR3 Hard Steering!!!!!Fixed!!!! Triumph 4
healeyboz Intermittent problem finally fixed Spridgets 6
ModifiedBJ7 A-H Fixed-Head Coupe Austin Healey 20
zimmy fixed the gearbox?! bearings and bullets? Spridgets 4
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
Baz Vacuum advance fixed! Spridgets 9
RickB FIXED - Distributor removal 'emergency' [not] MG 39
RickB Distributor pull - 25D - ideas please? - FIXED! Spridgets 2
T Fixed Battery Leak-I hope Triumph 13
X Sagging door fixed MG 2
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
C Alternator is Fixed! Triumph 2
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
SCguy Get oil pressure gauge fixed or just find another Triumph 12
ncbugeye Can these be fixed without a complete repaint? Spridgets 11
Banjo Fixed my dads "clunk" MG 3
J Fuel Gauge fixed almost. Triumph 5
M Acceleration Fixed MG 1
Scott_Hower DOT5 brake fluid leak FINALLY fixed ! MG 11
SCguy Overdrive Fixed! Triumph 3
7 booo ya!!!!! i fixed that baby. MG 5
Sherlock Wedge spotted at a car show... TR8 fixed-head-coupe Triumph 4
J 1958 xk150 fixed head jaguar coupe Jaguar 3
Kim de B MGB MGB leaks - fixed MG 5
