fixed the gearbox?! bearings and bullets?
zimmy
well ,i decided to pull the shifting
rods and try to get all those bullets
and bearings out so i could clean out
the holes real good, and out pops the top
one on the cover side, (3rd,4th gear)
and it comes out round edge first!
now im not really a pro at trannys,
but doesnt the round end go to the inside?
if so, my troubles may be over!
smooth sailin from here....whatcha think?
....z
jlaird
Round end goes in or against the shift rod.
zimmy
zimmy
ya , ive rebuilt it....
ive got it pretty well
back together,
except i cant get the screw
to snug up on the bearing
underneath...the one
with the felted washer
bolt....
whats the problem?! ...z
bugimike
Something isn't lined up if it won't seat all the way!
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
Flash_Harry MGB Fixed a miss! MG 7
F How is the fron valance on BT7 fixed to the car? Austin Healey 1
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
F How is the leading edge of the rear quater trim panel fixed on a AH BT7? Austin Healey 16
Gray_Cat Lotus Elan Fixed Head Coupe FS Malibu CA Lotus 3
Got_All_4 TR2/3/3A Door handle can this bee fixed Triumph 1
Healey Nut Can this be fixed ?? Austin Healey 24
P Fixed gas smell Triumph 0
nevets sputtering issue fixed...it was the timing Austin Healey 4
hondo402000 TR6 TR6 More issues fixed Triumph 3
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
drooartz I fixed something! MG 17
M Weeping fuel pump fixed Triumph 0
richberman Adjustable shock mounts or fixed? Austin Healey 16
Pythias Speedo ...... pffft..... fixed. Spridgets 3
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
martx-5 TR2/3/3A Fixed the tach on my TR3...Sort of Triumph 10
sparkydave Now what? [fixed!] Spridgets 12
H HS6 Fixed needle centering tips Triumph 1
T 1989 xj6 FIXED! Jaguar 2
mountainman TR2/3/3A TR3 Hard Steering!!!!!Fixed!!!! Triumph 4
healeyboz Intermittent problem finally fixed Spridgets 6
ModifiedBJ7 A-H Fixed-Head Coupe Austin Healey 20
angelfj1 Link to Smiths Heater Article Now Fixed Triumph 0
Baz Vacuum advance fixed! Spridgets 9
RickB FIXED - Distributor removal 'emergency' [not] MG 39
RickB Distributor pull - 25D - ideas please? - FIXED! Spridgets 2
T Fixed Battery Leak-I hope Triumph 13
X Sagging door fixed MG 2
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
C Alternator is Fixed! Triumph 2
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
SCguy Get oil pressure gauge fixed or just find another Triumph 12
ncbugeye Can these be fixed without a complete repaint? Spridgets 11
Banjo Fixed my dads "clunk" MG 3
J Fuel Gauge fixed almost. Triumph 5
M Acceleration Fixed MG 1
sparkydave Just when you think it's fixed.... Spridgets 7
Scott_Hower DOT5 brake fluid leak FINALLY fixed ! MG 11
SCguy Overdrive Fixed! Triumph 3
7 booo ya!!!!! i fixed that baby. MG 5
Sherlock Wedge spotted at a car show... TR8 fixed-head-coupe Triumph 4
J 1958 xk150 fixed head jaguar coupe Jaguar 3
Kim de B MGB MGB leaks - fixed MG 5
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
