1989 xj6 FIXED!
Tophatchef
Well, since I got my Jag several months ago, I have had just about every mineral oil related problem I can think of.
I fixed a leaking mineral oil reservoir.
I also believe that I've fixed a leaking suspension
I have replaced a brake accumulator
In the time of this whole mess, I have spent upwards of $150 on solely mineral oil.
Of course, there must be some questions...
I know that a bad accumulator can lead to a low brake pressure warning, and an anti-lock failure. I had these two warnings before replacing my brake accumulator, and I still do have these warnings. Now, I did procure my new accumulator from an "88 at a local junkyard. I think to myself, well, the brake pedal is considerably easier to pump down, but could this new accumulator be failING, as opposed to completely gone like my old accumulator? Please, any information regarding this problem is greatly appreciated.
Steve
Platinum
Firstly, I am happy that you have got this car almost sorted, I have been monitoring your progress and all the stumbling blocks along the way.
It could well be that the new accumulator is on its way out, but I would not have expected the lights to start coming on until it actually did go south on you. My gut feeling is that since they never went away, they probably just need to be reset. My BMW of similar vintage is that way, the warnings do not automatically go away once an errant part has been replaced. It may need a trip to a dealer to do that, or if there is a good, independent import specialist reasonably close-by they may well be able to reset things for you.
I suspect that there may be a DIY solution as well, but it will need the input of our resident Jaguar gurus to be able to know for sure.
T
Tophatchef
Well, I thank you for your support. It seems that once I fix a problem, another arises. Now, the car won't start, and it's most likely the starter, but that's another thread all together.
T 1989 xj6 not starting [again] Jaguar 1
T 1989 Jaguar xj6 key and headlights Jaguar 7
T 1989 Xj6 Rims Jaguar 28
T 1989 xj6 Considering re-doing the wood Jaguar 3
T No a/c in my 1989 xj6 Jaguar 2
T More leaking mineral oil from my 1989 xj6 Jaguar 9
T 1989 Xj6 Not Starting Jaguar 8
T 1989 xj6 warnings Jaguar 4
T 1989 XJ6 Brake problems Jaguar 11
T 1989 Xj6 Cupholders? Jaguar 4
T 1989 XJ6 air conditioning Jaguar 1
J For Sale For Sale in Seattle, WA: 1989 Jaguar XJ-S Convertible_$11,200 Jaguar Classifieds 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
J 1989 XJ-S Brake Light Relay Location? Jaguar 1
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
