1989 xj6 not starting [again]
T 1989 Xj6 Not Starting Jaguar 8
T 1989 xj6 FIXED! Jaguar 2
T 1989 Jaguar xj6 key and headlights Jaguar 7
T 1989 Xj6 Rims Jaguar 28
T 1989 xj6 Considering re-doing the wood Jaguar 3
T No a/c in my 1989 xj6 Jaguar 2
T More leaking mineral oil from my 1989 xj6 Jaguar 9
T 1989 xj6 warnings Jaguar 4
T 1989 XJ6 Brake problems Jaguar 11
T 1989 Xj6 Cupholders? Jaguar 4
T 1989 XJ6 air conditioning Jaguar 1
J For Sale For Sale in Seattle, WA: 1989 Jaguar XJ-S Convertible_$11,200 Jaguar Classifieds 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
J 1989 XJ-S Brake Light Relay Location? Jaguar 1
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
