XJ6 engine swap into XK 150
I recently picked up a fuel injected 4.2 engine that had been rebuilt by reputable shop in Memphis, Tn. I know a person that has a XK150 drophead with bad engine. Engine is a 3.8 and not original to the car. To satisfy my ownself today I pulled the fuel injection system off and installed a Triple SU set up on it. fit perfectly. Put XKE exhaust manifolds on, perfect fit, install trans bell housing, same good fit. Didn't have motor mounts but engine bolt holes same place. Anyone know why this engine shouldn't be fine to use in the 150?
marv
LarryK
I would personally do the same. Basically same engine but cooling ports inside a different, I don' t foresee a problem if not going for concours. Still a XK 150 and he'll have one that only a Jag person would know different.
MCL
Try to use an XJ6 4 speed OD tranny too, they are way better than the Moss box. You can get them in the UK.
LarryK
That could be hard as none of the US XJ6s had manuals. Might try the later 4.0L XJS, but only grey markets were imported.
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
J 1997 XJ6 engine vibration Jaguar 4
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
M 87 Series III XJ6 Rough Running Jaguar 16
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
M 1985 XJ6 Drivers door lock Jaguar 5
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
TonyPanchot 1997 XJ6 Fuel Filter Location Jaguar 1
M Won't Start-1995 Jaguar XJ6-Why Jaguar 8
T Just bought a 1997 Xj6 L Jaguar 1
M Adjustment of XJ6 Door Locks with Keikert Solenoid Jaguar 5
tony barnhill Tackling My '85 XJ6 Again Jaguar 18
M 1994 xj6 ride height Jaguar 1
S 91 XJ6 rear shocks needed Jaguar 3
T Noise coming from my '89 xj6's rear Jaguar 24
brendanf Starting Problems Jaguar XJ6 1982 Sovereign Jaguar 10
