'72 XJ6 Door Seal Installation
BruceAllcorn
I'm new to this forum, so I hope I'm doing this correctly. I've had a 1972 XJ-6 since 1975 that has been parked for the last ten years. I'm getting it back in shape and I'm almost there (if you ever really get there). I ordered a replacement front left door seal and it appears that the base of the seal is "pressed" into a channel. However, I'd like to hear from someone who has knowledge in the replacement of these seals before I start - the old one doesn't want to just pull out and I don't want to remove it until I know the correct procedure for doing so and the correct procedure for installing the new one. Can anyone help?
Regards,
Bruce
LarryK
When you get the ordered seal, pull or rip the old one out. As you have the replacement in hand you will then be able to see how it is installed. Sometimes you have to use a screwdriver to pull get it out of the channel. These seals are a straight forward and easy replacement. Glue where necessary and tape ( masking or painters not duct or cellophane ) until dry. Use 3M weatherstrip adhesive.
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
R Jaguar XJ6 Door Locks Jaguar 8
M 1985 XJ6 Drivers door lock Jaguar 5
M Adjustment of XJ6 Door Locks with Keikert Solenoid Jaguar 5
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
M 87 Series III XJ6 Rough Running Jaguar 16
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
TonyPanchot 1997 XJ6 Fuel Filter Location Jaguar 1
M Won't Start-1995 Jaguar XJ6-Why Jaguar 8
T Just bought a 1997 Xj6 L Jaguar 1
tony barnhill Tackling My '85 XJ6 Again Jaguar 18
M 1994 xj6 ride height Jaguar 1
S 91 XJ6 rear shocks needed Jaguar 3
T Noise coming from my '89 xj6's rear Jaguar 24
brendanf Starting Problems Jaguar XJ6 1982 Sovereign Jaguar 10
T 1989 xj6 not starting [again] Jaguar 1
T 1989 xj6 FIXED! Jaguar 2
