brendanf
Hello there from Perth Australia,
I have just bought a Jaguar XJ6 1982 Sovereign (imported from the uk in 1995 and not running.
I will try to explain what she is doing and what I've done, and been told to do and hopefully someone with knowledge about the 4.2 litre 6 with a degree in Lucas can help.
The car has been sitting for 2 years before I purchased it, and it worked when it was parked. The Engine was fully reconditioned by a Jag dealer 15,000 kms ago at an expense if some $15,000, so the fault can't be too major I would think.
The fuel might be a bit old, but I topped it up so it should be reasonable enough to start or @ least fire. The points & plugs are new, but the previous owner tried to fix the windscreem wipers and lost instruments on the dash (I think unrelated to the starting problem, but I could be wrong).
When you try to start it, it turns over great, and tries to fire, but just doesn't quite make it, very close though. I put starter fluid in the air intake after the airflow meter and it fires up and runs until the starter fluid runs out. I then tried spraying petrol (Gas) into the air intake of the air flow meter by holding the trap door open and it ran ok again, but it did blow the hose off on the engine side (scared the heck out of me).
I had a road side assistance guy come and try to get it to work, and he diagnosed the injectors as having very low voltage going to them, not 12 volts as thought, he thought it could be an earthing problem, but he wasn't sure so he gave me the name of a mobile mechanic with Jag experience. The mechanic said it was a computer problem and it would take a couple of days to fix (it's a plug in replacement,I thought he was only after what little money I have left).
I had the computer checked for faults by an electronics expert (no Jag experience) and he couldn't find any faults on the boards, I have a new one on order anyway.
With the low voltage to the injectors I thought it might be the ignition amplifier, I was told by Jagbits it was under the bonnet, but I can't find it, can someone tell me were it is please, maybe its unplugged.
Another guy said the airflow meter could need replacing, but would that cause low injector voltage? Anyway the previous owner did check it, and took the cover off the top @ some stage. I tried to start it by opening it half way thinking the air would help, but nothing changed.
Anyone with Jag experience, or knows someone to refer me too, or who is familiar with these faults, your advice would be greatly appreciated.
Cheers,
Brendan Perth Western Australia
Cheers,
