I would also want to inspect the throttle plate and bore. Look for wear on the shaft or bushings (moves up and down, in and out), and see if you have a bunch of buildup in the bore that needs to be cleaned.
Had a TR8 yesterday with that issue....not buildup, rather throttle plate not quite centered, rubbing on the bottom slightly, holding the idle up to 1200 or so until you manually pulled the throttle shut, then 750.
Dave
