Overdrive Fixed!
SCguy
Well... actually it just started working. Some of you might remember that my overdrive would engage correctly, but not disengage until I turned off my car at which point I would hear a click and all would be back to normal. Now it's working as it should. Any thoughts... Do you suppose something was just clogged.
In any event, I'm just glad that it will be working for the Dixon, CA British car show!
TR4nut
In case it happens again, here is a wild guess: maybe a bad relay switch that sticks on until the current goes off? This would make the overdrive switch and all the interlock switches useless.
One way to test is to stop in neutral while it is still misbehaving and keep everything running, then pull the connections off the relay - if it disengages, replace that relay.
Randy.
SpannerMan
Not sure if it was covered in the earlier thread or if you already know, but just to be on the safe side - you don't want to back up - ever - if your overdrive is stuck engaged. There is a unidirectional clutch that can get destroyed by doing so. The first thing to check on the electrics is the functioning of the interrupter switches etc. just by turning on the ignition and moving the o/d switch and the gear lever and listening for the solenoid clicking at the appropriate times. I would disable the thing electrically personally if anything in that seems suspect, until such time as you have to rectify it. Pete
simpzimmer
Mine will not engage on really cold mornings until the car warms up. I only tried once. I've really dreaded ever having to work on my overdrive, they look really complex...
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
