J-H 907 sparks to life!
Ray Brandes
Today we got our Jensen-Healey 907 engine started. It really isn't running.
The only way to keep it going was to hand choke the rear Stromberg.
We didn't look at the carbs at all, but now I have kits on order and that should do it.
It was sitting for a number of years and I am hoping when we run it some more it will quit smoking.
A lot of thanks to folks on this and other forums.
First Start Video
https://ray-vin.com/jensen-healeyfirststart.mp4
JPSmit
well done! and I love that hi tech engine stand! :smile:
R
Ray Brandes
Because the left and right motor mounts are at different heights we couldn't use the "clubs" engine stand without serious modification.
The blocks of wood were a lame attempt at keeping the motor level.
JPSmit
:cheers: any port in a storm :smile:
LarryK
Congrats!
R
Ray Brandes
While waiting for the carb kits, we are going to dose the cylinders with Marvel Mystery Oil. Let is set for a week. Hopefully it will loosen up the rings for less blow by and smoke.
NutmegCT
Ray, I've never used MMO. But when I first got my MG, I found uneven cylinder compression. I dropped some SeaFoam into each cylinder, let it sit for 24 hours, then did another compression test. All cylinders had increased at least 5 psi, and the one which was 95 psi (instead of around 120 like the others) had moved up to 115.
Can't complain there!
Tom M.
waltesefalcon
Marvel Mystery Oil is the best. I think that this is one of those personal preference arguments, ala Triumph or MG, though.
R Plug gap for 907? Lotus 4
J Identifying Lotus 907 engine castings [Jensen H] Other British Cars 8
JamesWilson Lotus 907+ Lotus 5
Tullamore 907 oil pressure Lotus 9
DrEntropy 907 cams! Lotus 7
D Distributor clamp upgrade? 907 engine. Lotus 5
aeronca65t 907-powered Pinto Other British Cars 6
JamesWilson Rebuilding Lotus 907 - Parts acquired, Advice? Lotus 4
S Lotus 907 oil seals Lotus 3
JamesWilson Rebuilding Lotus 907 Engine Lotus 17
Keoke Peugeot 907 Other Cars 14
B 907 Engine , oil separator Lotus 1
B um..scary mini-lightning like sparks when starting!!?? Spridgets 5
TexasSprite Smoke and Sparks Spridgets 0
BierRunner TR6 Life without Spark :( Triumph 25
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
drooartz MGB Bringing the B back to life MG 36
Rut TR4/4A Life Magazine Triumph 3
Rut Life Magazine Spridgets 4
T Recently acquired BJ8 needs life Austin Healey 5
W Brake Hose shelf life Austin Healey 11
S TR6 life of TR6 hydraulics Triumph 5
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
H Richmond VA 1960 Bugeye Bringing Miss Eva back to life. Spridgets 453
JPSmit Spotted Mercedes SLS - and life is good Other Cars 0
BlueMax Such is Life Spridgets 11
dklawson General Tech Cautionary Note On Clutch Life Triumph 2
Nelson Back to life Spridgets 8
Superwrench My BT-7 comes back to life ! Austin Healey 18
Superwrench My BT-7 coming back to life ! Austin Healey 12
AN5Sprite Tunebug comes to life Spridgets 10
SeldomSeen Spitfire Just Once in my Life, I'd Like to Drive a Spitfire Triumph 9
T for the life of me I can't remember Triumph 5
S life after block seal Triumph 1
T TR2/3/3A Average life span of a TR3 Coil Spring? Triumph 5
J Spark Plug life Triumph 24
Tabcon First Signs of Life! ... See it on You Tube NOW! Racing 2
T Slightly OT - shelf life of rebuild calipers Triumph 8
John_Mc New life to old radio? Triumph 4
regularman Wild life! Spridgets 4
tahoe healey battery life Austin Healey 4
abarth69 It has life Vroom,Vroom Spridgets 2
RickB Life on Mars - lbc MG 14
T Will I be risking life and limb...15 shim soup Triumph 4
hilsideser Shelf life ? Restoration & Tools 2
G A good way to waste 1/2 an hour of your life Other British Cars 6
kodanja 1/2 life? Triumph 30
PeterK GT6 Nice GT6 on Life On Mars last night. Triumph 4
RickB Life with two running LBC's - nice! Spridgets 12
